oil stumped
Old Apr 5, 2010 | 08:00 PM
rick-73's Avatar
rick-73
ill try get a new one tomorrow. got it pulled already looking to see if the oilpump rod was broke but its good. the bottom gear tho on dit. pretty goudged hope thats it!
Old Apr 5, 2010 | 08:02 PM
danr1's Avatar
danr1
As Lew stated yes, that gear drives the distributor and the oil pump.
What did you do about it, replace the gear? If so when? During the original pump replacement or just now?
Old Apr 5, 2010 | 08:04 PM
rick-73's Avatar
rick-73
did nothing yet just seen pulled it and noticed it. so itll be after i replaced oil pump. should i replace whole distributor or can i just change that gear?
Old Apr 5, 2010 | 08:09 PM
dustybumpers's Avatar
dustybumpers
check to see if the vacum hose to the map sensor came un done when you jacked up the motor. it will act just like that if it is un hooked
Old Apr 5, 2010 | 08:14 PM
rick-73's Avatar
rick-73
wheres that located at?
Old Apr 5, 2010 | 08:16 PM
rick-73's Avatar
rick-73
my first ford so dont know much about their location of stuff took me 3 hrs to find where the damn oil press. sensor was! lol
Old Apr 5, 2010 | 08:19 PM
danr1's Avatar
danr1
How many miles on it?
The bushings in a dizzy wear over time, that creates timing fluctuations if bad enough.
It also has the PIP (profile ignition pickup) inside it, it can be known to cause issues similar to what you experience. Stalls out, wait a while and it will start again, then stalls again wait starts again etc etc.
PIP can be replaced while you have the dizzy out.
I don't know at this point that that is the problem you have, just wanted to point that out.
A whole new dizzy may be the better way to go.
Again, a complete lack of oil and or oil pressure will not prevent the motor from running. It doesn't know if it has oil or pressure or not. So that is not what causes your motor to stall, you have something else causing that.
Old Apr 5, 2010 | 08:37 PM
dustybumpers
look on the firewall above the heater, a rectangle with wires and a hose, hose goes to the plenum with the rest. I had an 89 blow a motor mount 1 time pulling the travel trailer, it ran just like that until I got home and found it had pulled the hose off, ran great, but would not idle at all.
rick-73's Avatar
rick-73
checked the map sensor it plugged in.only hope is the dist.
Old Apr 5, 2010 | 08:44 PM
rick-73's Avatar
rick-73
my map sensor mustve been replaced cuase mine just layn on the heater core and old one still bolted on! lol lazy suckers
Old Apr 6, 2010 | 01:18 PM
rick-73's Avatar
rick-73
put new distributor on it and does same thing. dunno what else could be
Old Apr 6, 2010 | 03:48 PM
rick-73's Avatar
rick-73
if i took the truck to get codes read would autozone still be able to get a code if check engine light doesnt come on?
Old Apr 6, 2010 | 03:58 PM
  #28
danr1's Avatar
danr1
You had a bad dizzy gear but even at that you should have run a self test first, see what if anything it'd tell ya.
How to run a self test> Ford Fuel Injection How To Run a Self-Test
Check Engine Light on or not doesn't matter, the KOER and CM tests may lead you to the problem.
However if you disconnected the battery the CM has been cleared and will no longer be able to help you. The KOER test will be your only real hope of the computer helping you out.
Then its to the basic simple quick tests to narrow down what system is the failure,
Key "on" power to the positive side of the coil? crank position? (red-light green wire)
Does it have spark? Pull a plug, does it spark during "crank"?
Pump any fuel? Do you hear the fuel pump run for a couple seconds then quit when the key is turned to the "run" position? If not you should.
If so how much pressure at the fuel rail?
Hold your hand on the fuel rail, feel the injectors pulsing during crank?
Check some of that over and let us know the results, you may find a problem before getting through the short list.
Old Apr 6, 2010 | 06:41 PM
  #29
rick-73's Avatar
rick-73
im getting 63 21 and 16 on the koer
Old Apr 6, 2010 | 06:47 PM
  #30
dustybumpers
was it doing this before the new pump?
