Sun Visor SAG !!!!!!!
Old Apr 4, 2010 | 09:36 AM
ozark1's Avatar
ozark1
My '84 F-150 suffers from the Drivers side sag. Has anyone found a fix ?..thanks..j
Old Apr 4, 2010 | 10:11 AM
desperado_18_2000's Avatar
desperado_18_2000
This is one of my peeves with my truck at the moment as well. I cant seem to find a fix either to keep my sun visors up where they are supposed to be and it drives me nuts! The only solution I've come up with is to convert to XLT/Lariat style sun visors that have the support on the inside ends to support the visor.
Old Apr 4, 2010 | 11:03 AM
newrider3's Avatar
newrider3
When I did the license plate interior on my truck, I bent up a couple small brackets that the visors slide into to hold them up.
Old Apr 4, 2010 | 12:18 PM
Crankylove's Avatar
Crankylove
I had the same trouble with both my visors. I put some small, powerfull magnets on the trim at the front of the roof, which help them in place there, but they still bounce around if you had to move them.
I finally just went to the junk yard and pulled some out of an '93. They require drilling one new hole in the cab roof (for the center support clips), but otherwise bolt right in.
Old Apr 4, 2010 | 03:38 PM
desperado_18_2000
I think when i head back to the junkyard in a few days I'm going to get the sun visors out of the truck i got my seat from, just to solve this issue once and for all.
Old Apr 4, 2010 | 04:05 PM
Fordzilla80's Avatar
Fordzilla80
I have a set of the newer retainer clips,but I haven't looked at them in awhile.Is it possible to just enlarge the center of the opening so our 80-86 visors just rest in the opening?I know that currently they won't fit in there unless you cut some of the material off.
Old Apr 4, 2010 | 04:54 PM
Archion's Avatar
Archion
Veteran: Marine Corps
You can install a set of later visors, 87+ along with the clips, it works fine
Old Apr 4, 2010 | 06:21 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
1980-1986 does not have the center clips.
1987-1996 have the center clips.
Just get the visors and center brackets out of any 1987/1996 F-truck.
Also 1987-1991 Customs, and Base Models have vinyl visors that closely match the originals.
Just be extremely careful when you drill the holes for the mounting of the center clip. The roof is double walled but if you get too zealous you may just drill a hole through your roof.
big meat
Bronco II
Apr 10, 2022 12:38 AM
MTP55
Sep 10, 2016 11:48 AM
Roger T. Pipe
Aug 4, 2016 07:07 PM
Goodstuff
Appearance & Dress-Up
Jun 1, 2016 10:09 AM
bigboss80
Jun 27, 2014 08:34 AM
