pyrometer ?
Old Apr 2, 2010 | 05:02 PM
powerstroke1869's Avatar
powerstroke1869
pyrometer ?
Thanks to my new mbrp exhaust i have to reinstall my pyrometer probe.. before this exhaust i had it post turb. now i want to put it pre turbo.. if i put it in the up pipes do i need the clamps or can i still drill and tap the pipe. if i can drill and tap do i need to worry about the flakes getting into my turbo?
Old Apr 2, 2010 | 05:07 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
You are heading in the correct direction to move it pre-turbo. You can drill and tap the up-pipe or the manifold, either will work just fine.
When I do the up-pipes I either leave the truck running and/or put a magnet in the hole after I am done. Any beyond that won't hurt anything.
Be sure to wear eye protection though.
Old Apr 2, 2010 | 05:19 PM
powerstroke1869
so if i do the up pipes i need to keep the engine running? also do i start with a smaller bit and work my way up?
Old Apr 2, 2010 | 06:22 PM
ChunderDownUnder's Avatar
ChunderDownUnder
I drilled a pilot hole, then used a magnet and grabbed the wifes vacuum cleaner (dont tell her) and sucked anything I missed.
Old Apr 2, 2010 | 06:57 PM
Izzy351's Avatar
Izzy351
I drilled the up-pipe, tapped, and installed the adapter & pyro sensor with the truck on a lift. Almost all of the shavings will fall out -- any inside will blow out through the turbo.
Old Apr 2, 2010 | 07:49 PM
Izzy351's Avatar
Izzy351
Looks like you're missing something there, Brian...
Old Apr 2, 2010 | 08:12 PM
damicofuel's Avatar
damicofuel
Has anyone put it in the exhaust collector y ?
Old Apr 2, 2010 | 08:14 PM
Izzy351's Avatar
Izzy351
Not that I know of -- too hard to get to, Jay! And it's better closer to the engine, anyway.
Old Apr 2, 2010 | 08:17 PM
damicofuel's Avatar
damicofuel
Hay thanks for the info Joe, I have mine in my power elbow now but want to get it to pre-turbo
Old Apr 2, 2010 | 08:23 PM
ChunderDownUnder
Is this it Joe ?? got the uppies as well
Old Apr 2, 2010 | 08:36 PM
damicofuel's Avatar
damicofuel
Think he was refering to the missing block heater plug!!!
Old Apr 2, 2010 | 08:45 PM
Izzy351's Avatar
Izzy351
Indeed I was...
So whatcha got there, Brian?? You said you weren't getting a 38r, but it looks like a stock housing to me...
Old Apr 2, 2010 | 08:56 PM
ChunderDownUnder
No need for a BH here in AUS. Just a stock one bro. It needed a rebuild so I got it coated was I there. That was done about 4 mths ago.. I will be building a new motor in next 6 mths
tje2015
16
Mar 3, 2012 07:02 PM
csangster
Oct 18, 2010 10:35 AM
Milwaukee,WI
Dec 28, 2005 11:35 AM
edub32
Apr 5, 2005 08:20 PM
mrcobra350
Jan 15, 2004 07:41 PM
