Pyrometer Band-Clamp or Drill and Tap?
on
on
I don't know about the Autometer product but drill and tap on the driver's side exhaust manifold is the way many of us have gone. Preturbo mounting of the probe gives you a more responsive and more accurate reading of EGT.
Most just do the drill and tap with the manifold still on the truck but a number of us have gone to the trouble to remove the manifold and do the drill and tap off the vehicle. It's not that hard to do.
drill, no tap
here is what i did.. i was going to weld a fitting onto the exhaust behind the turbo, i saved that for plan B ...because once you put a hole in you exhaust. you stuck doing it, so i had very little room to work as you know i got a really long drill bit.. i would say it was about 15 inchs long.. got some where home depot or someplace.. anyway right behind turbo, but not on turbo maybe 2 inchs behind, but before my exhaust wrap started .. i drilled a hole . long bit was great because no room for drill...so then i put the clamp around prob.. had to us 2 because the one that came with it was only 3in.. so i add one and i also used a around part off of another exhaust gasket, for a gasket and screwed down clamp, worked great and no leaks.. if it had leaked then i was going to weld fitting over hole but little room to work, so did not want to try this
... anyway email me if you want and i will send pics of work
chad
chadjones99 @ direcway.com (no space's)
(Click Here to find out why email addresses are removed from posts.)
chad
heres a pic of mine, i think the same as you are looking at...went with the band on the manifold
http://home.comcast.net/~mjs122276/w...e-skip-30.html
on
There are a number of posts where guys discuss their methods for dealing with the shavings when the manifold is drilled. Some use a greased swab and wave that around inside the hole after it is drilled and some just have the truck idling and it blows out the chips as the drill is cutting through.
meter install
ok, listen drill behind the turbo, there for no shaving go into they will just go out the exhaust. and I was reading the info that came with my meter it says " on turbo engine's mount behind turbo on exhaust pipe.. on no turbo mount to manifold " so this is what I did. no shaving going through the turbo. as if it fail's they will say you did it and no warranty !
on
pyro's are meant to be drilled 4-6" after the exhaust valve in the head, on 2 strokes you actually place them where visually the pipe flame changes color internally. After the turbo you are getting a cooler temps and the temps are also regulated by the turbo, any faster change will be averaged out because of the large area of the turbo. They might tell you after the turbo because of the shaving issue. Remove manifold is the best, other wise grease drill bit and vacuum as you drill; it only takes 1 bad misguided shaving to wedge in the o-rings.
