Sponsored by: Real Truck
roll on bed liner...
Old May 27, 2003 | 08:56 AM
gramps-truck's Avatar
gramps-truck
Talking roll on bed liner...
I finally tried the Rustoleum kit.... It is basically the same as the Hurculiner. Make sure whatever kit you get is a two-part EPOXY kit. The Duplicolor kit at WalMart is a Vinyl/paint base - junk. I bought 2 gallons from www.sportsmansguide.com for $30 a kit (cheaper if you join their club) and sprayed it on with a $20 undercoating gun. It looked EXCELLENT !!!! I did think that a few areas were a little thinner than I wanted, so I ordered a third gallon. I rolled it on with the Duplicolor roller cover, NOT the Rustoleum cover - it is much smoother now, but there are a few runs and "puddles" where I did not do a great job of rolling. If I were to do it again, I would buy 4 kits from sportsmans guide and spray it all on at one time. With shipping and all, it would still be about $150 and would look like the $450 jobs.
Old May 27, 2003 | 12:50 PM
RockRoad's Avatar
RockRoad
Smile roll on bed liner...
Maybe you have a chance to make a real tuff off roader! Buddy of mine rolled on the rustoleum liner on his scuff plate on the door and also the foot plate on the door frame, plus the lower 18" of the body/doors on both sides and the rear... Now I have to admit, he's a serious offroaderand frankly doesn't care about how it looks -- though it looks just fine to me on his dark gray F350 which is also his shop truck.
RR
Old May 27, 2003 | 03:42 PM
daimon1054's Avatar
daimon1054
I have a spray on liner, it was there when I bought the truck. It started pealing up so I bought some roll on at Wal-mart and use it to patch any scratches or spots where the spray on came off. To me the roll on seams to stick better. I am guessing the shop that spraied the liner did not do it's prep corectly. So make sure you scuff it well then clean it!
Old May 29, 2003 | 11:31 AM
bddo's Avatar
bddo
So far, the Rustoleum kit is working out great... It has really helped with items in the bed sliding around, and it still looks great.
I have to admit, I haven't really hauled anything heavy, except my ATV, and it is still fine. I had a car battery tip over and leak acid all over the place, but it didn't seem to faze it.
For $50, I still think it was a great investment.
Old May 29, 2003 | 02:05 PM
rmilchman's Avatar
rmilchman
I currently have a herculiner that is a year old. I have a choice of rolling more herculiner, or attempting to spray rustoleum on top. I'm affraid that if I try the rustoleum that it won't properly adhere to the herculiner.
Old May 30, 2003 | 08:03 AM
bddo's Avatar
bddo
rmilchman,
I'm not sure about the Herculiner, but I did roll on additional coats of the Rustoleum kit after the first coats had set for about a month. I haven't seen any issues with it not sticking to itself.
Old May 30, 2003 | 02:10 PM
SMB's Avatar
SMB
Hey, I have a plastic dura-liner or whatever. Took it out the other week to sweep up underneath. The paint is worn to metal in many places from the liner and I don't like that. How do you think the roll on stuff would work to protect the bed from the plastic liner?
-SMB
Old May 30, 2003 | 02:15 PM
bddo's Avatar
bddo
Not sure...but for $25, it would be worth a shot...even if you have to roll it again every couple of years...
Old May 30, 2003 | 03:39 PM
rmilchman's Avatar
rmilchman
Where did you get it for $25?
Rich
Old May 30, 2003 | 03:49 PM
gramps-truck
go to www.sportsmansguide.com and do a search for bedliner or rustoleum. They have it for $29. Also, if you buy more than 1, do a search on the internet for "sportsmans guide coupons" and you should find a quite a few different codes for a savings of $5 or $10 dollars off of your purchase.
Old May 30, 2003 | 04:42 PM
rmilchman's Avatar
rmilchman
Thanks, order placed.
yfz 450
6.7L Power Stroke Diesel
31
Jun 30, 2014 11:47 AM
76ClydeF100
13
Feb 18, 2014 09:52 PM
Bob07FX2
Aftermarket Products
Dec 17, 2007 08:59 AM
sportscar
Paint & Bodywork
Jul 31, 2007 10:07 AM
sportscar
All Things Towing
Jul 30, 2007 07:11 PM
