Sponsored by: Real Truck
drivers window won't work when outside temp is high.
Old Apr 1, 2010 | 02:31 PM
Fishin76's Avatar
Fishin76
Just like it says. It's been 80 here in IL for the last 2 days, and my drivers side window quits working after about 10am as the day warms up. Later in the evening, when it cools down, it starts working again.
Is there something in the window motor, like the door lock actuator, that would prevent the motor from working if it gets hot.
anyone know / taken one apart?
Old Apr 1, 2010 | 02:41 PM
scottzj's Avatar
scottzj
Hangin 10 bra
It sounds like the window motor is slowly going out. Luckily the truck is a large one, so its not as hard as those hondas or toyotas. You can alway steal a switch from another side to plug into the drivers side wires to see if that helps or run a "loop back" wire to make the motor work (bypassing the switch).
Old Apr 1, 2010 | 10:25 PM
Fishin76's Avatar
Fishin76
Is it just the switch then? When the motor works, it works just the same as the passenger side. No slowing down, works in both directions, nothing to make me think its the motor. But, If I knew the problem, I wouldn't be here asking now would I.......
Old Apr 2, 2010 | 02:24 AM
redford's Avatar
redford
FTE Leadership Emeritus
You could try spraying the tracks with silicon spray.
Old Apr 2, 2010 | 04:16 AM
tnvnl's Avatar
tnvnl
Most small electric motors have a thermal protection unit inside them to prevent burnout in case of a stuck or shorted switch, sounds as though yours may be bad.
teamlx88
May 21, 2015 08:30 AM
justgunner
1978 - 1996 Big Bronco
Sep 3, 2013 10:14 PM
00expo&earlybronco
Aug 30, 2004 12:10 PM
FINFEVER
Electrical Systems/Wiring
Sep 2, 2003 01:34 PM
