Power window problems
Old Jan 2, 2014 | 05:29 PM
teamlx88's Avatar
teamlx88
Suddenly out of nowhere my driver side window has stopped going down. It seems as if the window would go up as the interior lights dim when I hit the switch.
I took the door apart and jumped the window motor and it worked in both directions so I thought I just needed a new switch. After replacing the switch the window still wont go down (all other windows are fine). Could it be the GEM doing this? Anyone else had a problem like this? Any advice here would be great. Thanks
Old Jan 2, 2014 | 10:08 PM
alloro's Avatar
alloro
Back when I had my 97 Expedition and before I had the windshield resealed, after a heavy rain or a car wash I would have issues with the window not going down. A couple of warm days later it was all dried out and the window worked perfect again.
Old Jan 3, 2014 | 01:57 PM
teamlx88's Avatar
teamlx88
Which points to the GEM or fusepanel as the problem
Old Jan 3, 2014 | 02:15 PM
alloro's Avatar
alloro
No, it points to a bad windshield seal, which is allowing water to drip into the GEM or fuses.
Old Jan 3, 2014 | 02:26 PM
teamlx88's Avatar
teamlx88
Unfortunately it had not rained for a while here when the window stopped working. Its been over two weeks already and there is no change.Where does the windshield leak? I want to fix this permanently.
Old Jan 3, 2014 | 02:56 PM
alloro's Avatar
alloro
There are many posts and threads regarding the leaking windshield. You should have no trouble finding them when using the search feature.
Old Jan 5, 2014 | 09:56 PM
teamlx88's Avatar
teamlx88
Well I used the search feature and got nothing about where the leak is
Old Jan 6, 2014 | 07:48 PM
alloro's Avatar
alloro
The whole windshield has to come out, the surfaces cleaned, then it get's reinstalled correctly. I suggest going into an auto glass shop and having them do it so that it comes out right. It doesn't take much to damage a windshield if the installation is off just a hair.
Old May 19, 2015 | 02:06 PM
Skunberg's Avatar
Skunberg
Did you find your window problem?
Old May 21, 2015 | 08:30 AM
teamlx88's Avatar
teamlx88
Yes. After removing the kick panel I found the door harness plug had gotten wet and rotted. I replaced the plug with one from the junkyard and the window works again
Jeff heine
Dec 18, 2016 04:42 PM
Kelly Aitken
May 6, 2013 02:37 PM
Big Ruth
Jun 25, 2010 04:46 AM
JFH
May 8, 2007 10:05 PM
