modified up-pipe
Old Apr 1, 2010 | 08:34 AM
patrickke's Avatar
patrickke
modified up-pipe
ok If i get one of the up pipes (sneaky pipes) is that all i need to do? I am saying what else is part of doing one of these up-pipes? Or is it better to just run a plug in the pipe and weld her shut?
Old Apr 2, 2010 | 05:15 AM
Maxium4x4's Avatar
Maxium4x4
If you have the resources you can modify your own pipe. Here is the before and after all in one picture of how I did mine. The finished pipe is above with the piece removed welded shut which is used to block off the EGR cooler. I roll the turbo out, unbolt the up pipes and ****** the whole assembly out the top.
Old Apr 2, 2010 | 10:05 AM
smokersteve's Avatar
smokersteve
patrikky, cut that little tube that branches off to the side and weld a metal plate over the hole.
Old Apr 3, 2010 | 06:29 AM
Randy777's Avatar
Randy777
I just drove a freeze plug into the hole. Took about 5 minutes. Then installed it as before. Of course getting it out and back in took me almost 4 hours.
Old Apr 4, 2010 | 08:21 PM
rickf92592's Avatar
rickf92592
Doesn't the 'scoop' in the up-pipe restrict flow to the turbo?
Seems like you'd want that out.
Old Apr 4, 2010 | 08:42 PM
smokersteve
of course!!!
Old Apr 4, 2010 | 09:13 PM
rickf92592's Avatar
rickf92592
Originally Posted by smokersteve
of course!!!
But driving the freeze plug only solves half the problem.
Old Apr 5, 2010 | 03:36 AM
Maxium4x4's Avatar
Maxium4x4
The 04 the original poster has doesn't have the scoop in the up pipe, so you can actually just drive a plug into the pipe feeding the cooler.
Old Apr 5, 2010 | 11:11 PM
Randy777's Avatar
Randy777
Thats right, mine had no scoop. The freeze plug was $.75. But getting that pipe out was a pain. I also passed my smog with flying colors.
kruc
26
Aug 9, 2016 11:46 AM
agsmv1
Nov 7, 2015 10:11 PM
97-psd
Sep 2, 2015 09:45 PM
agsmv1
Aug 7, 2015 04:44 PM
70T351W
Aug 11, 2009 08:48 PM
