April Chat thread anyone?
Old Apr 2, 2010 | 09:33 PM
  #31
bill11012's Avatar
bill11012
Modular motor junkie
Hahaha, Your funny.
Old Apr 2, 2010 | 09:42 PM
  #32
fepowerguy8's Avatar
fepowerguy8
So despite my harassment of my friend to buy a Ford or Dodge he bought another Chevy truck. It has what appears to be a dana 60 rear end and I have other dana 60 rear ends. The problem his has the 4.56:1 gears and I have one that has the 3.73:1 gears. It would be nice to switch the gears, but if I recall you need some special tools to do this like a spreader or something. Am I right? If so it might be easier to just swap rear ends. I've only changed gears in ford 8 and 9 inch rear ends. The dana 60 is quite a beast to be taking in and out and the gear swap may or may not be an easy swap.
Old Apr 2, 2010 | 10:22 PM
  #33
bghnkinf250's Avatar
bghnkinf250
What type Chevy? A Dana 60 can be a pain to set up since it needs set up bearings and such. It can be done without a spreader.
Old Apr 2, 2010 | 10:33 PM
  #34
fepowerguy8
He got an 86 extra heavy duty 1 ton with a 454 and it has the hydraulic brake booster that hooks up to the power steering pump and coolers for everything. Ya figured it would be easier to swap rear ends than change gears, guess it's time to measure stuff to make sure it will fit. The rear end I have came out of a 79 Ford 1 ton, if it don't fit I have a hammer and duct tape Changing rear ends in my Falcon was pretty easy, could hold it up with one hand. I think it would be easier on the truck to roll it on its roof and drop the rear end in with a cherry picker
Old Apr 2, 2010 | 10:40 PM
  #35
bghnkinf250
Yeah.....Good luck with that rolling it over thing I want to see photos!!!!! In 1986, GM used the Dana 70 in the one ton duallies, but also used the 14 bolt in the 1 ton single rears (and maybe some duallies) that is not to say thay did not use the Dana 70's in single rear apps. in oddball applications. Make sure it is even a Dana first.
If you go to swap gear sets and carriers, be ready to replace the carrier. I saw a lot that spun the bearings on the flange side of the carrier.
Old Apr 2, 2010 | 11:01 PM
  #36
fepowerguy8
Ya I gotta figure out what it has first. It looks similar the the dana 60's I have, it could very well be a dana 70. It is a single rear wheel, it does have a few things I have not seen in awhile, definitely made for pulling barns down. Sill rather have a Ford one ton with a 460.
Old Apr 2, 2010 | 11:13 PM
  #37
greyghost85's Avatar
greyghost85
shut up and go to bed
Old Apr 2, 2010 | 11:17 PM
  #38
bghnkinf250
Are we keeping you up?
Old Apr 2, 2010 | 11:19 PM
  #39
fepowerguy8
I am sleeping, only have to get up in 6 hours.
Old Apr 2, 2010 | 11:21 PM
  #40
greyghost85
you're young....you can hang
Old Apr 2, 2010 | 11:23 PM
  #41
bghnkinf250
Only 9:00 over here. Wife is out getting a little more ofr Easter and I am with the kids.
Old Apr 2, 2010 | 11:25 PM
  #42
greyghost85
do you eat balogna pie on Easter? its a tradition here
Old Apr 2, 2010 | 11:26 PM
  #43
fepowerguy8
It's 11:30pm here, I should go to sleep, lots of logging to do in a few hours. Always best to run the chainsaw when you're half awake though.
Old Apr 2, 2010 | 11:28 PM
  #44
greyghost85
how many fingers ya got?
Old Apr 2, 2010 | 11:31 PM
  #45
bghnkinf250
Balogna pie? Never heard of it, but sounds Tasty! What is it?
