April Chat thread anyone?
Old Apr 11, 2010 | 03:57 PM
  #61
Chitownhillbilly's Avatar
Chitownhillbilly
Throw a full gas can in the back, Fill up, note mileage and drive till she runs out. Put gas in and head to the gas station. Now you know roughly how many miles you can go on a tank.
Who needs a gauge??
Actually, the Gauge was broke in my 85 in High school and I ran out of gas somewhere around 30 times in the year and a half I owned it
Old Apr 11, 2010 | 07:17 PM
  #62
bill11012's Avatar
bill11012
Modular motor junkie
I know base on tank size and MPGs.
I could do that with the 83, but on the 90 I can't run it out like that.
Oil burners do not like to start when you get air in the lines.
Old Apr 11, 2010 | 11:53 PM
  #63
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I ran my '91 out a few days ago (yard truck), today I dumped 5 gals of diesel in it, poped the hood, hooked up the remote button, grabbed a small stick and held the schrader open, by count 14 it had fuel, unhooked the remote start, jumped in turned the key on let the plugs heat, cranked and it was running by count 9....
Whats so hard about running a diesel out of fuel.
I drove a Ford powered VW Bug for over 10 years without a gas gauge, never ran out!
-Enjoy
fh : )_~
Old Apr 12, 2010 | 12:00 AM
  #64
76f350spercamprspeal's Avatar
The gauge on my truck hasn't ever worked...
Come to think of it, nothin' on my dash board works....
Oh Well, It'll peel tires in every gear, totally worth it!
Old Apr 12, 2010 | 12:16 AM
  #65
bill11012's Avatar
bill11012
Thats not too bad. I thought after that, you had to loosen each injector line until fuel came out.
So pretty much doing what you said, 8 more times.
I have never run a diesel out, thats just what I have been told.
Old Apr 12, 2010 | 12:59 AM
  #66
Festus Hagen
Methanoholic
Old school... Diesels of old school have a dead headed fuel system, since the invent of the return style fuel systems, bleeding injectors is basically moot on most systems.
It can help, but is not needed.
Don't get me wrong, there could be reasons for needing to bleed each injector, if the injectors have a high pop and the IP is weak, it may not push the air thats in the injector lines past the injector.
-Enjoy
fh : )_~
Old Apr 12, 2010 | 03:56 PM
  #67
TheKirbyMan's Avatar
TheKirbyMan
Well I tried the "run-er-til-she-runs-out" method....I ran out of gas about two minutes after I filled up my gas can. LOL. I was in the turn lane to get out of the parking lot, and it just stopped. No drama, it just stopped. I turned on my hazards and proceeded to fill 'er up from the gas can, and after about three starting attempts, I was on my way. And I now have an idea of how far I can go on $10 gas.
10.00 / $2.91 = 3.4 gallons...
Trip odometer reading at fillup: 101mi
Trip odometer reading when I ran out: 131mi
So...30mi / 3.4gal = 8.8mpg.
Not too bad. Could be better. :\
Old Apr 12, 2010 | 09:23 PM
  #68
$2.81 !!!!!!!!!!!!!!!
Thats' Insane! CHEAP!
(Compared to the prices, of $1 more out here...)
California....Enough Said
Old Apr 12, 2010 | 09:41 PM
  #69
Rogue_Wulff's Avatar
Rogue_Wulff
Dang. I pay 2.65 for 100% gas, E10 can be got for 2.59.......
I was out in cali back in feb, and paid well over $3 gallon, but it was for diesel.....
Old Apr 12, 2010 | 09:48 PM
  #70
About a year or so it was $5+ for a gallon of Diesel, It hurt each time we filled up our Diesel!
Old Apr 12, 2010 | 10:02 PM
  #71
TheKirbyMan
Regular 87 octane is like $2.67 or something. I'm running premium, cuz it seems to give me a little better mileage.
EDIT: They should have included foldaway pedals for our trucks. That way we could just use people power when fuel prices get crazy...lol
Old Apr 12, 2010 | 10:09 PM
  #72
Rogue_Wulff
After leaving cali, I never paid more than $2.79/gallon for diesel. Since I flew out to drive the truck back, it wasn't my money I was spending, but I still bought the lowest cost available.
Old Apr 12, 2010 | 11:26 PM
  #73
newrider3's Avatar
newrider3
Regular is $2.59/gal here, and at 11mpg~ish, I find myself filling it up at least once during the week.
I'm not sure why some of you guys have regular as 87 octane, around here regular is 85.
Old Apr 12, 2010 | 11:36 PM
  #74
Rogue_Wulff
Wow. 85 octane? I guess high altitude needs less octane than us flatlanders. Around here, 87 is the lowest available.
On the other hand, I wish I could find 70 octane for my RX7. Mazda won several championships using 67 octane fuel back in the early 80's. The rotary doesn't suffer from detonation issues, unless you add lots of timing advance or boost. Lower octane burns faster......
Old Apr 13, 2010 | 10:47 AM
  #75
ctubutis's Avatar
ctubutis
Correct.
Google it, there's plenty of info on this out there; here is a Wikipedia explanation [0]:
United States, in the Rocky Mountain (high altitude) states, 85 AKI is the minimum octane, and 91 AKI is the maximum octane available in fuel. The reason for this is that in higher-altitude areas, a typical naturally-aspirated engine draws in less air mass per cycle due to the reduced density of the atmosphere. This directly translates to less fuel and reduced absolute compression in the cylinder, therefore deterring knock. It is safe to fill up a carbureted car that normally takes 87 AKI fuel at sea level with 85 AKI fuel in the mountains, but at sea level the fuel may cause damage to the engine. A disadvantage to this strategy is that most turbocharged vehicles are unable to produce full power, even when using the "premium" 91 AKI fuel.
[0] Octane rating - Wikipedia, the free encyclopedia
