removing front diff.
Old Mar 31, 2010 | 11:08 AM
MMSGuthrie110's Avatar
MMSGuthrie110
I am replacing the front diff on my f150. its a dana 44 twin I beam. i have all bolts removed, driveshaft is removed. only thing holding it in is the axles. how do i get it out? please dont tell me i have to take one of the hubs completely off...
Old Mar 31, 2010 | 11:13 AM
Conanski's Avatar
Conanski
Yes you have to take one of the hubs apart, the drivers side would be best because the drive axle simply slides into the diff. You will also have to take a clip off the boot over the slip joint in the passenger side drive axle because the inner portion of that axle is c-clipped into the diff.
Old Mar 31, 2010 | 11:20 AM
MMSGuthrie110
okay thanks. i guess i will start taking that apart.
Old Mar 31, 2010 | 01:38 PM
MMSGuthrie110
so whats the easiest way to get the driver side axle out? i have to hub off and i removed the nut off the upper ball joint but can't get the lower off. do i really have to take the ball joints off to do this?
Old Mar 31, 2010 | 04:46 PM
Conanski's Avatar
Conanski
No that's not right. You have to remove the hub guts and then the wheel bearing retainer nuts with the special socket, the outer hub and rotor assembly will then come off in 1 piece. Then the inner hub has to come off by removing the 6 bolts(I think) that fasten it to the yoke and prying it off.. which may take some persuasion with a BFH and chissel. Then the side axle will simply unplug from the diff.
Old Mar 31, 2010 | 05:05 PM
zxwut?'s Avatar
zxwut?
Get yourself a manual before you keep on trucking. Next thing, you'll be taking off the tailgate to air up your tires.
Old Mar 31, 2010 | 05:08 PM
MMSGuthrie110
my problem was that i couldn't get the spindle off but i'm going to get the puller tomarrow. and i don't need no dam manual lol
Old Mar 31, 2010 | 06:21 PM
zxwut?'s Avatar
zxwut?
You'd be amazed how much easier working on anything is with a manual; you'll break fewer things also.
Old Mar 31, 2010 | 08:46 PM
fordman1090's Avatar
fordman1090
Get a big rubber mallet, and a a can of PB Blaster. Soak it in PB, Hit it HARD from all directions, soak it in some more PB, repeat till it comes off.
Spray the PB first thing, the longer it sits, the better it works
Used that method on a 85 bronco axle, was heck getting the 1st one off, quit for the night and in the morning i got to the other side and it came off in my hand because i had sprayed it when i first started and it had sat overnight.
wfodickinson
Apr 3, 2011 11:43 AM
fordboy2
Jan 10, 2010 08:35 AM
marioc956
Offroad & 4x4
Aug 1, 2007 06:37 PM
Monkeyman13
1997 - 2003 F150
Jun 27, 2007 05:23 PM
Bushy
Aerostar
Jun 11, 2005 07:01 PM
