removing front driveshaft
Old Jan 9, 2010 | 09:04 PM
fordboy2's Avatar
fordboy2
how do I remove the front drive shaft? I removed the 4 nuts and the ubolts at the diff. how is it held to the transfer case? I was expecting it to slide out but does not seem to do that thanks in advance.
Old Jan 9, 2010 | 09:33 PM
RRranch's Avatar
RRranch
I think it was 8 mm head bolts on the transfer case by the double cardan joint there. I just had mine off. There are 4 of them holding it on
Old Jan 10, 2010 | 07:53 AM
fordboy2's Avatar
fordboy2
are they a normal hex headbolt?
Old Jan 10, 2010 | 07:56 AM
RubberDuck's Avatar
RubberDuck
There are 4 bolts that bolt to the front output flange. Some have allen bolts, some have regular bolts. After you get those out, you may have to bump it with a hammer to get it to break loose. But there are bolts at the transfer case.
Old Jan 10, 2010 | 08:11 AM
yoslick's Avatar
yoslick
+1 Break out the BFH if it's the first time it's ever been removed!! Almost like it's welded on there!!
Old Jan 10, 2010 | 08:35 AM
live2wheel's Avatar
live2wheel
+2 on the BFH! sometimes things just need it.
Jaysch44
1997 - 2003 F150
May 28, 2009 01:43 PM
Jape1
Jul 20, 2008 08:57 AM
orgnova
2004 - 2008 F150
Sep 6, 2007 06:01 PM
cutlac
Jan 8, 2005 02:21 PM
dnroberts
Aug 12, 2004 12:47 PM
