i would have to second that as well they are cheep enough and way way less of a pain in the *** most parts places will have a good selection in store and most of it comes with the coil around it that alone i think is extra good
yeah, kinda .. got in too too deep when "doing a simple cab and motor swap' .. ended up stripping it down to a rolling frame to give the frame a coat of rust 'resistant' paint ..
looking to redo all the brake lines and hoses .. gonna buy a coil of the pretty powder coated stuff, the nuts I need and gonna need the tool to do the flaring .. figure it's the better way to go .. unless I need multiple sizes ..
actually thinking I might be able to do the long fuel line runs with the 'pretty powder coated stuff' as well .. thoughts and ideas ?? ( if I could loose the 'Ford Quick Connect Fuel Fittings' I'd pay extra )
Can't you just order the lines from l.m.c prebent and ready for the truck. Then if you wanted them powder coated you could take them in or do it yourself if you have the knowledge.
