Windows update question.
Old Mar 30, 2010 | 07:17 AM
Lazy K's Avatar
Lazy K
Running XP Pro set for auto updates. Got an update downloaded and I don`t want to install it. How do I remove the uninstalled download?
The little messages at startup and shutdown telling me to install it are driving me crazy.
And yes, I have changed the settings so that, hopefully, I only get updates that I want downloaded.
Thanks for any help.
Old Mar 30, 2010 | 07:30 AM
Furyus1's Avatar
Furyus1
Unless someone else has any other ideas, I believe you'll have to let it install the update then use system restore to rollback the update... If you have a restore point set shortly before the update, you shouldn't have any problem...
If it's the SP3 update, I ran SP3 on a few machines and didn't have any problem with it...
Old Mar 30, 2010 | 09:25 AM
donjamer's Avatar
donjamer
If you are getting the pop up in the system tray on the lower right saying Updates are available then it hasn't installed..
Possibley failed to install..
All you need to do is uncheck the box to install it and then it will give you another option to never show it again..
Check that box and the problem should go away..
What is the update it's trying to install??
Old Mar 30, 2010 | 11:04 AM
Virto's Avatar
Virto
Change your settings in security center, in the control panel, to prevent automatic installation. There should still be an automatic download option, but one that requires your input to install. Personally, I make sure security center is set to never notify, and then go out from time to time and look for updates myself. That way I never get the annoying popup, and I know just what is being installed.
Unless it's a major update, like SP3, IE8, MediaPlayer11 and so on, there is no uninstall option under add/remove programs. A rollback to the last restore point is usually the only option.
Old Mar 30, 2010 | 12:46 PM
Lazy K's Avatar
Lazy K
Thanks to everyone who replied. But donjamer you are the man. Followed your instructions-yellow icon gone.
It was something that said it would offer me a choice of browser to run along with IE7. It also said that once installed it could not be removed.
And virto I think I will follow your advice to avoid a similar problem in the future.
Furyus1, I already have SP3 with no problems. I didn`t want to install it because of the warning that once installed it couldn`t be removed.
Thanks again to all. You guys are magic.
ford2go
Dec 2, 2011 07:48 AM
ford2go
Oct 26, 2009 06:56 AM
bigrigfixer
Dec 9, 2008 12:43 PM
ford2go
Jul 5, 2008 09:55 PM
theologian
Feb 12, 2004 02:58 AM
