Help removing door panels
Old 03-29-2010, 04:42 PM
Butter03's Avatar
Butter03
Butter03 is offline
I have a 2010 f150 sxt supercab and I want to upgrade speakers, but not sure how to take off door panels.. Any inputs will be appriciated. Thanks
Old 03-30-2010, 04:05 PM
ReAX's Avatar
ReAX
ReAX is offline
There should be 2-3 screws in the door panel and then either push pins or lift tabs. Pull out the door/window switches and if you have a lamp/reflector, pull it too. Also look behind the door handle for screws.
Once you have 2-3 screws removed, then try lifting the door panel up (parallel to the door). If it doesn't lift, then try prying a corner back just enough to look behind it.
Old 04-01-2010, 05:43 AM
Butter03's Avatar
Butter03
Butter03 is offline
OMG what a cluster f*#k I've got myself into . I've got the door panel half on, half off and can't get it back on or off . The door handle/trim seems to be connected/ hard mounted to the door itself. Any suggesstions anyone.
Old 04-01-2010, 06:03 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
Maybe these will help. They're also in my gallery, or send me a PM with your e-mail address and I'll send you a pdf.
Old 04-01-2010, 10:15 AM
Butter03's Avatar
Butter03
Butter03 is offline
Thanks I sent you a pm .I have 2010 STX supercab .
Old 04-01-2010, 10:39 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
No PM received.
Old 04-01-2010, 01:31 PM
Butter03's Avatar
Butter03
Butter03 is offline
Maybe I did'nt do it right, I saw the pic you put up but it was to small to read.
My email is tidbit_03@hotmail.com
Old 04-01-2010, 01:33 PM
shotgunz's Avatar
shotgunz
shotgunz is offline
E-mail sent.
Suprawill1
Escape & Escape Hybrid
05-25-2019 01:13 PM
SeaCarr
16
06-12-2016 12:37 PM
likeagoodbook
02-11-2013 07:09 PM
400inatruck
07-11-2012 01:28 AM
billy13
1997-2006 Expedition & Navigator
12-14-2009 10:29 AM
Quick Reply: Help removing door panels
