Sponsored by: Innova
Help removing door panels
Old Mar 29, 2010 | 04:42 PM
Butter03's Avatar
Butter03
I have a 2010 f150 sxt supercab and I want to upgrade speakers, but not sure how to take off door panels.. Any inputs will be appriciated. Thanks
Old Mar 30, 2010 | 04:05 PM
ReAX's Avatar
ReAX
There should be 2-3 screws in the door panel and then either push pins or lift tabs. Pull out the door/window switches and if you have a lamp/reflector, pull it too. Also look behind the door handle for screws.
Once you have 2-3 screws removed, then try lifting the door panel up (parallel to the door). If it doesn't lift, then try prying a corner back just enough to look behind it.
Old Apr 1, 2010 | 05:43 AM
Butter03's Avatar
Butter03
OMG what a cluster f*#k I've got myself into . I've got the door panel half on, half off and can't get it back on or off . The door handle/trim seems to be connected/ hard mounted to the door itself. Any suggesstions anyone.
Old Apr 1, 2010 | 06:03 AM
shotgunz's Avatar
shotgunz
Maybe these will help. They're also in my gallery, or send me a PM with your e-mail address and I'll send you a pdf.
Old Apr 1, 2010 | 10:15 AM
Butter03's Avatar
Butter03
Thanks I sent you a pm .I have 2010 STX supercab .
Old Apr 1, 2010 | 10:39 AM
shotgunz's Avatar
shotgunz
No PM received.
Old Apr 1, 2010 | 01:31 PM
Butter03's Avatar
Butter03
Maybe I did'nt do it right, I saw the pic you put up but it was to small to read.
My email is tidbit_03@hotmail.com
Old Apr 1, 2010 | 01:33 PM
shotgunz's Avatar
shotgunz
E-mail sent.
Suprawill1
Escape & Escape Hybrid
May 25, 2019 01:13 PM
SeaCarr
16
Jun 12, 2016 12:37 PM
likeagoodbook
Feb 11, 2013 07:09 PM
400inatruck
Jul 11, 2012 01:28 AM
billy13
Dec 14, 2009 10:29 AM
