Brake adjustment
Old Jan 26, 2003 | 07:13 AM
51truck's Avatar
51truck
Brake adjustment
Just finished complete brake overhaul on 51 F1. I have always adjusted brakes to where you get a little drag on drum. A freind says get a little drag then back off so ther is no drag. Which is correct? Thanks
Old Jan 26, 2003 | 08:04 AM
Earl's Avatar
Earl
Brake adjustment
56 Shop manual says "Rotate the adjusting screw with a suitable tool until the shoe begins to drag against the drum. Back off the adjusting screw until the drum can be turned without shoe drag."
Old Jan 26, 2003 | 10:42 AM
BELLM's Avatar
BELLM
Brake adjustment
Ditto Earl. Otherwise you will prematurely wear drum, shoes, increase fuel consumption, etc. Havent done F1 adjustment in a while, usually 6, 8 10 clicks clicks back after snug works well depending on the number of teeth on the adjuster star wheel. You are going to have to play with each wheel make sure one doesnt lock up before the other. One of the advantages of living on a gravel road, can tell real quick if not all evenly adjusted.
Old Jan 26, 2003 | 07:19 PM
57_ford's Avatar
57_ford
Brake adjustment
Just one thing to add I find it is better to crank the adjuster down until the wheel locks and then back them off. This gets the shoes centered and seated in the drums.
doug51f1
Dec 3, 2014 10:25 PM
fordno1
Jun 7, 2011 03:59 PM
mhalter
Aug 1, 2003 07:59 AM
51truck
Feb 3, 2003 07:56 AM
AjRagno
1997 - 2003 F150
Jan 11, 2003 10:31 PM
