05 6.0 problems
Old Apr 1, 2010 | 05:49 PM
  #31
william_04_x's Avatar
william_04_x
Originally Posted by gearloose1
The way I do it may not work for most of you.
On the E Series, I can pop the doghouse, and basically (with some mirrors mounted) see everything visually as I drive along.
Now, I know visual checks sound kind of quaint... but I swear by it.
You're right, that won't work for trucks or Excursions.
For F series, how about mounting a remote cam with its own LED lighting, feeding the output to a display / recorder on a laptop inside the cab?
That's a good one..
April Fools Day, right?
Old Apr 1, 2010 | 05:59 PM
  #32
gearloose1's Avatar
gearloose1
Originally Posted by william_04_x
That's a good one..
Dead serious. Do not trust computer readouts alone.
A visual / audible noise check under actual operating conditions is priceless for diagnostics.
FYI, I also instrument parts that are suspected --- with sensors --- and then read them.
You can get cheap sensors for almost anything --- strain gauges, temperature, vibration, cameras from UV to IR, position sensors, etc.
Old Apr 1, 2010 | 06:09 PM
  #33
william_04_x
Please take the time to set up your camera and mirrors to take a video of the EGR and/or VGT solenoid operating while you're driving.
What parts do you see moving?
I predict an Academy Award for special effects in your future.
Old Apr 1, 2010 | 07:01 PM
  #34
gearloose1's Avatar
gearloose1
Well, high on the priority list is a thermo image scan of the Turbo as it warms.... and look inside so to speak.
Here is what I am thinking of... but I am waiting to get one of these at nearly as good a deal as I got the truck for first...
http://www.flir.com/thermography/ame...tent/?id=14610
If you want to donate a IR cam for me.. I take donations!
That will enable me to see what / where is unusually hot... or cool...
Or... if you are really interested in being my benefactor... I want one of these:
http://www.flir.com/thermography/ame...tent/?id=14614
Standard equipment on police choppers and cruisers equipped to seek out and find grow ops.
Old Apr 5, 2010 | 01:20 PM
  #35
T TA 53's Avatar
T TA 53
What should I do about reading the codes for free? autozone? Can I buy a obdII plug for my laptop? The truck takes minutes to start when warm now.My egts also got up to 1100 with the ac on. Can I just clean the turbo? What way does the egr move? So I can see if its sticking. When I pulled the egr the intake was clean and dry with carbon on egr.
Old Apr 5, 2010 | 01:22 PM
  #36
T TA 53's Avatar
T TA 53
I see an 05 Excursion for sale in the near future. Where is the cheapest place to get the parts and what parts do I need to clean the turbo? oil larger drain seals etc? The tech page for turbo removal was messed up last I checked. Thanks
Old Apr 8, 2010 | 10:30 AM
  #37
T TA 53's Avatar
T TA 53
Acutron scanner didnt show any codes.
leegrisham
Jun 5, 2016 08:36 PM
Bigdawg5565
All Things Towing
19
Feb 4, 2016 07:10 AM
underthebridgejim
Jun 15, 2015 11:47 PM
don766
2004 - 2008 F150
13
Jul 18, 2014 05:06 PM
Philippi
All Things Towing
Aug 11, 2011 06:40 AM
