05 6.0 problems
Old Mar 31, 2010 | 10:33 AM
T TA 53's Avatar
T TA 53
How do I go about checking. Fart? The 6.0 doesnt have a wastegate? When I let off the bov is whats making the sound right?
Old Mar 31, 2010 | 11:41 AM
Sarge261's Avatar
Sarge261
It will make like a chuff chuff noise. You will hear it most of the time, light to moderate load. Normally you would hear this on a good turbo under a heavy load/hard accel condition and then a quick release of the throttle.
There is no blow off or waste gate on the 6.0. The noise you hear is boost pressure release through the intake system.
Sarge
Old Mar 31, 2010 | 11:47 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Here' a good example of 6.0 "turbo fart"
YouTube - 6.0L Powerstroke SCT Tuned "Turbo Fart"
Old Mar 31, 2010 | 05:45 PM
T TA 53's Avatar
T TA 53
Thats what it does.
Old Mar 31, 2010 | 05:52 PM
Sarge261's Avatar
Sarge261
Looks like you need to remove the turbo and have it rebuilt, or do it yourself. There is a write up in the tech folder on how to do it. I am not sure what the kit costs from Ford.
Luckily my truck was still under waranty when it happened to me. The first time it wa sthrowing a low boost code and was farting, they rebuilt it. The second time it needed a center section so it got a new turbo, feed line, and drain pipe. So while you have it out you may as well install these parts too, they are cheap.
I did see a few new center sections on ebay for less that 200.00 but that was a while ago.
Or maaybe call BD or one of the other vendors and upgrade?
Sarge
Old Mar 31, 2010 | 05:59 PM
gearloose1's Avatar
gearloose1
If you are not in the habit of spending money, I cleared up mine nicely with some spirited runs... and need to redo it every few weeks.
Old Mar 31, 2010 | 07:00 PM
T TA 53's Avatar
T TA 53
Spirited runs? Has problems starting when I dont let it idle very long when warm also.
Old Mar 31, 2010 | 08:05 PM
gearloose1's Avatar
gearloose1
You need to check for a stuck / sticking EGR valve while you are at it..
Check for VGT servo operation while you are at it.
Old Mar 31, 2010 | 08:59 PM
bismic's Avatar
bismic
You might want to elaborate on how to do these checks you are suggesting.
Old Mar 31, 2010 | 09:34 PM
IB Tim's Avatar
IB Tim
You need to submit a service ticket with a real email address.
Thanks
Old Mar 31, 2010 | 09:57 PM
T TA 53's Avatar
T TA 53
Thanks
I signed in through yahoo email account. Let me know what Im missing.
So I might just get away with cleaning the turbo? Looked at the tech folder for about 2 hrs today. This will have to bring the mpg up.
Old Apr 1, 2010 | 07:09 AM
Sarge261's Avatar
Sarge261
I think you have a combination of things going on too. The turbo sticking will still allow you to drive when cold.
Describe what else it is doing when cold, is there anyway you can moniter some stuff for us, like FICM voltage. Also is the charging system up to snuff?
Like stated before, you may want to remove the EGR valve and have a look at it. Also check the intake for any signs of coolant/moisture, if you do deleting/replaceing the EGR and oil cooler would be ideal while you have that turbo out of the way.
Sarge
Old Apr 1, 2010 | 09:08 AM
  #28
gearloose1's Avatar
gearloose1
The way I do it may not work for most of you.
On the E Series, I can pop the doghouse, and basically (with some mirrors mounted) see everything visually as I drive along.
Now, I know visual checks sound kind of quaint... but I swear by it.
For F series, how about mounting a remote cam with its own LED lighting, feeding the output to a display / recorder on a laptop inside the cab?
FYI, here is someone (on a Mercedes) who rigged up a manual VGT link:
YouTube - Custom VNT actuator 2
Old Apr 1, 2010 | 10:08 AM
  #29
T TA 53's Avatar
T TA 53
I meant to check if the egr was sticking when I cleaned it. I didnt want to break it . What way do you move it?
Old Apr 1, 2010 | 10:46 AM
  #30
IB Tim's Avatar
IB Tim
I need you to send me your yahoo email address...use the support system...thanks
