6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
coolent level?
Old Mar 28, 2010 | 09:39 AM
whporwil's Avatar
whporwil
coolent level?
Should it be at the cold level mark on the dgas bottle when cold or is there a reason to keep it lower?
Old Mar 28, 2010 | 03:33 PM
senix's Avatar
senix
anywhere in between the lines is good. I tend to keep mine at the upper line.
Old Mar 28, 2010 | 04:53 PM
stevestroke01's Avatar
stevestroke01
Mine stays at the lower line on the cold fill. I can fill it to the upper line but in a few weeks it is back at the lower line and that is where it stays.
Old Mar 28, 2010 | 06:13 PM
ruschejj's Avatar
ruschejj
No, don't keep it lower. Coolant runs through the EGR coolers, they need all they can get. The weak link to puking or hydro-lock. EGR cooler is a big deal, hydro lock will win you a new engine.
Old Mar 28, 2010 | 06:25 PM
whporwil's Avatar
whporwil
The lower level is where the dealer left it after a radiator replacement, that's why i asked.
Old Mar 28, 2010 | 07:04 PM
ssharber's Avatar
ssharber
Based on my experience with dealers, I'd do as everyone here advises and keep it at the top mark. The "dealer" left my transmission 3.5 quarts low after a radiator change. I DEFINITELY didn't keep it there. I keep my coolant level a little above the min cold line, as rush and senix state. Those egr coolers are a big deal and definitely don't need to suffer from low coolant levels.
Old Mar 28, 2010 | 07:28 PM
senix's Avatar
senix
you don't want that lower inlet on the degass bottle to be exposed and then the motor sucks in air.
Old Mar 29, 2010 | 07:10 PM
sawtooth's Avatar
sawtooth
Interesting
This is interesting. My truck is well above the lower inlet line but right on the cold mark on the bottle. That is since its warmer outside. During the real cold days it would be slightly below the low line or cold fill mark but well above the lower inlet hose. The funny thing is i could fill this up to the upper line and it slowly works back down to the same point after a few weeks. So now i no longer fill it up each month and it hasn't moved in 6 months except since its warmed up outside its now just above the lower hash line or cold fill mark. Also, i've noticed on the 2010 trucks the marks on the bottle are lower than they were on the 08's. Looks to me Ford has realized people were putting too much in the bottle. Not sure but i can't understand why they lowered the marks.
Old Mar 30, 2010 | 11:56 AM
ruschejj's Avatar
ruschejj
Sawtooth, any possibility that Ford finally got around to a new radiator design for the '10's? Might be a different system? Certainly should be....
Old Mar 30, 2010 | 12:13 PM
sawtooth's Avatar
sawtooth
not really sure but from what i can see everything looks the same except for the bottle. I would like to know for sure why the change though. All i know is if i get up toward the high mark on the bottle then i loose coolant and gain phosphorus in my oil analysis. Phosphorus is normally a sign of a coolant leak. The numbers are on the low side but obviously some coolant makes it into the engine somehow.
Old Mar 31, 2010 | 06:30 AM
capt caper's Avatar
capt caper
Mine was all over the place until I got it worked out and stuff replaced. It now is at the lower cold mark and gets up a little higher then the upper mark when warm. When it was cold out here this past week end it was down just a little like Sawtooth's does.
Old Mar 31, 2010 | 08:45 AM
sawtooth's Avatar
sawtooth
thats right in cold vs warmer weather (with the engine cold) the level will change 1/2" or so depending on outside temp.
chetspencer
May 21, 2021 11:40 AM
pony
Aug 1, 2012 06:20 PM
Saxon
Jul 9, 2012 04:38 PM
jl4407
Mar 23, 2012 10:48 AM
FSeybert
Jul 24, 2010 10:06 PM
