So where is it? Little recall sticker has MIN and MAX marks, for Cold level, is that with the cap on or off? I see a pretty big level change when the cap is loosened/removed and the system depressurizes.
it is for when the coolant is cold, so you can add or adjust level. You can't do it when it's hot, and shouldn't open that cap hot. I use the sticker and the "MAX" cold mark is about equivalent to the original LOW mark on the bottle.
Thanks,
Fred
I run mine about 1.5" below the min. line. I don't have any trouble with puking at this level.
Yeah, when I fill mine to the MIN line on the recall sticker, it drops to near the bottom of the degas tank when hot and under pressure. I had one instance of puking and can't replicate it. I think I may have had the level a little high, then drove it the first time we had over a 100 degree day. I'm hoping that was the only reason. I did however determine that my oil cooler is getting fouled and will be replacing it soon as well. Thanks.
