Leaking oil Cooler?
Old Mar 25, 2010 | 04:06 PM
Deerslayinrenek's Avatar
Deerslayinrenek
Leaking oil Cooler?
I had a leaking water pump so I replaced that, now it appears as if the oil cooler is leaking, not into the engine though....Is this common? and if so what usually causes the leak?......Is there any reason I cant just bypass is and run the hose right from the pump to the radiator? I dont wanna remove it, I just dont wanna use it.
Old Mar 25, 2010 | 05:10 PM
Bear 45/70's Avatar
Bear 45/70
You have a water cooled oil cooler? Never seen one, how about a pic.
Old May 19, 2010 | 08:58 PM
Shawn63200's Avatar
Shawn63200
leaking oil cooler
you can get a lower rad house from 92 f250 and it will go right to the waterpump port and by pass it. I guess it would be okay to just bypass it and just cap the ends to keep stuff out of the now empty coolant passages.
Frijole
23
May 24, 2016 10:11 PM
woodythefordboy
Dec 16, 2012 04:59 PM
jg96powerstroker
Dec 12, 2010 05:37 PM
bigdummyford
Jul 17, 2008 10:05 PM
