I have a 2004 f350 with the 6.0. I just chand the icp sensor and the hi pressure oil pump gasket along with the intake the egr cooler and all the small gaskets along the way. My leaks are all fixed. Now the truck dont wanna stay running its puttin out a code on the turbo solenoid and the odb_|| not reading. Anyone have any suggestions?
Im not sure i just put a new one in tho. The problem is in the wiring im sure. But it ran fine before i did this and now the solenoid on the turbo is stuck and wont hold a charge. It also has a new alt and both new batt.
Do you have any oil on the wiring? If yes your going to
need to get a pigtail repair kit for it. Also trace the wire back
and look to see if it is chaffing anywhere. A short will cause
you a lot of problems.
What were your problems before all this?
Why did you have to replace all these gaskets???
Do you have a SGII?? What scanner did u try in your OBD port?
I dont thnk faulty turbo solenoid will cause the truck to not run.
Do you do your own work? retrace your steps
ok the truck is running turns out the battires werent charged. i retraced all my steps all the wires a plugged in at the correct spot and the connections are clean.. I pulled codes p1000 obd-11 monitor checks incomplete. and p0603 pcm long term memory reset.. what do i do now?
I would say if it is running fine just drive it and try clearing the codes in a few days. you will get the p1000 anytime you have had the batteries disconnected for a given amount of time.
