460?
Old May 21, 2010 | 07:59 PM
2004460's Avatar
2004460
Unhappy 460?
ok i got problem maybe not though ok i bought a f100 with 460 in it ran good with only 2000 miles on rebuild just the motor was green lol so i pulled it and painted it ford blue and new gasket my ? is beford i took it out the oil pressure was about 40 when warmed up at idle i put a new gauge in and now its runin when warmed up about 10-15 psi idk if thats ok or not or do i need to look for something eles thats wrong?
Old May 21, 2010 | 09:08 PM
PatsPOS's Avatar
PatsPOS
Hmm...what type of gauge was in it originally (factory or aftermarket? mechanical or electrical?) and with what type of gauge did you replace it? It's not impossible for the factory-style sending unit to be FUBAR, and if you replaced a factory electrical gauge with an aftermarket mechanical gauge, the latter is more likely to be accurate.
FWIW, 10-15 PSI hot at idle, while not outstanding, is adequate. A long-standing rule of thumb is that you want to see 10 PSI on the pressure gauge for every 1000 RPM.
Pat
Old May 22, 2010 | 10:48 PM
phatjack81's Avatar
phatjack81
Sounds like either the 1st or 2nd gauge is bad since that's the only thing that changed. Take it to someone who has a good mechanical gauge to see which one is right.
2003pstroke123
Dec 6, 2013 06:43 AM
460Gene
Aug 25, 2008 12:05 PM
stepside64
Jul 5, 2004 06:34 PM
Home Solutions
Jan 31, 2004 07:54 PM
yellowrosefarm
Nov 22, 2001 09:52 PM
