Which coolant filter should I get?
Old Mar 24, 2010 | 08:57 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Ford Superduty Powerstroke 2003-2007 6.0L Coolant Filter Kit
http://www.dieselsite.com/index.asp?...ROD&ProdID=324
They look about the same other than one comes with more filters and is more expensive.
I am not going to do the EGR cooler delete so I am thinking I need a coolant filter. Am I right thinking that?
Are there any others that are as good for less money?
Thanks
Old Mar 24, 2010 | 08:59 AM
gearloose1's Avatar
gearloose1
Somewhere on here is a guy that kludged his own from Home Depot plumbing parts.
If you are doing this as a "bypass" filter that is in parallel... it is not that critical.
Old Mar 24, 2010 | 09:00 AM
02GrayPowerStroke
Maybe he will chime in.
I didn't mind DIY, but I will need some detailed instructions and pictures.
Old Mar 24, 2010 | 09:06 AM
gearloose1's Avatar
gearloose1
Look here:
https://www.ford-trucks.com/forums/7...nt-filter.html
The install that Maximum 4X4 did used NAPA parts.
Ball valves are found here:
https://www.ford-trucks.com/forums/7...ml#post7124058
Home Depot Tees
https://www.ford-trucks.com/forums/7...ml#post7124206
Measurements of hoses:
https://www.ford-trucks.com/forums/7...ml#post7124535
Baldwin CFB5000 Coolant Filter Base:
https://www.ford-trucks.com/forums/7...ml#post7125518
Napa Parts that Maximum 4X4 used:
https://www.ford-trucks.com/forums/7...ml#post7126113
NAPA FIL 4070 Coolant Filter, Height (Inches) : 5.214, 27 Micron - Taller Version Non-Chemical
NAPA FIL 4069 Height (Inches) : 4.317- Non-Chemical Filter, Thread Size (Inches) : 11/16-16
Fram Coolant filter PR3383
NAPA Filter Base (used as fuel or coolant) FIL 4019
Baldwin has a complete line of heater hose Tees
Step by step instructions here:
http://www.dfuser.com/Install%20Guid...filter_kit.pdf
Thanks to all the posters on this forum!!!!!
I intend to do the same....
BTW, there is also a DIY Fuel pressure (on engine) gauge...
Old Mar 24, 2010 | 09:15 AM
Firemudder's Avatar
Firemudder
Putting together your own kit is easy. I found the filters and filter base online. The rest of the stuff can be found at Home Depot or Lowes. Im waiting on my stuff that I ordered to come in. PM me if you would like the info on the place I found the filter and base.
Old Mar 24, 2010 | 09:47 AM
rickatic's Avatar
rickatic
The kits you linked too look so similar ai wonder if one is a repackaged version of the other. The mounting brackets for the filter base look identical. I thought about assembling my own kit. I changed my mind after doing some research here. Most guys that have tried the self made kit ended up with in $20 of the Dieselsite kit and had to do a lot off chasing. I ordered the complete Dieselsite pkg and 3 filters that arrived at my door for $165.00
Regards
Old Mar 24, 2010 | 09:50 AM
02GrayPowerStroke
Regards
That is what I am starting to wonder. I live an hour from the nearest Home Depot. I may go with the Dieselsite and call it good. But I am going to keep reading in the meantime.
Old Mar 24, 2010 | 09:51 AM
gearloose1's Avatar
gearloose1
$165?
Think I can do it with parts lying around for about $30!
Old Mar 24, 2010 | 10:44 AM
06silvercrew's Avatar
06silvercrew
I have done them for under $60. Base and filter from local IH dealer for under $40 and a few fittings from Lowes or HD.
If anyone is doing a DIY kit, I have a TON of extra AUTHENTIC 3/8'' goodyear HEATER hose. Its nearly impossible to find, so I ended up with a 50ft roll of the stuff.
Old Mar 24, 2010 | 01:09 PM
Firemudder's Avatar
Firemudder
Yeah I vote fo building your own. Its not hard and you save some bucks.
Also 06silvercrew if your selling the heater hose I could use 5-6 feet.
Old Mar 24, 2010 | 02:08 PM
06silvercrew
Yeah I will pass along some hose to anyone that needs it. PM me.
nmclella
Feb 9, 2015 01:42 PM
Bruin008
Dec 31, 2012 05:02 PM
75diesel
Jul 22, 2012 11:11 PM
MD250
Mar 16, 2011 06:17 PM
