head swap question
Old Mar 22, 2010 | 06:28 PM
jb65542's Avatar
jb65542
head swap question
will the heads off of an 89 mustang 302 work on a 88 f150 302 and if so do i need to change rockers, pushrods, or anything else
Old Mar 22, 2010 | 10:15 PM
Conanski's Avatar
Conanski
They're the exact same heads so don't bother if you're doing this for an upgrade, but if you need heads because yours are worn then yes it's a direct swap with no other changes necessary.
Old Mar 22, 2010 | 10:16 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Yes and your stock valve train parts should be fine.
Old Mar 23, 2010 | 06:01 AM
jb65542's Avatar
jb65542
the truck keep overheating and the head or head gasket is the only thing that we havent changed. it only overheats after it has been running for like 45 minutes
Old Mar 23, 2010 | 10:56 AM
Kemicalburns's Avatar
Kemicalburns
what kinda fan and radiator are you running and what temp Tstat?
if you had a head gasket leak or cracked head you should see evidence on the spark plugs or stains on the block.
dogstar
21
Nov 11, 2010 12:39 PM
GendoIkari69
Feb 26, 2002 10:30 PM
airharley
Feb 19, 2002 01:34 PM
johnm132
Mar 1, 2001 04:26 PM
RAILMAN
Sep 5, 2000 02:48 PM
