302 heads on 289
302 heads on 289
I just recently traded a '79 F-150 2wd with 302 for a '69 F-100 with a 289 bored 60 over. It has a set of stock 302 heads on it. Is this a advantage or disadvantage? My freind said 302's had lower compression than 289's but he also said 302 heads would have bigger valves. Does he know what he's talking about? I would think they would be an advantage. I'm in the process of getting ready to rebuild it. What are your suggestions about this??
Thanks,
Jeff
Thanks,
Jeff
302 heads on 289
Jeff - According to Pat Ganahls' book, Ford Performance. There is almost no difference between the 302 and 289 heads. NO advantages. I have a copy of a good book on rebuilding Ford small blocks, but I loaned it to a friend. The title is How to Rebuild your Ford Small Block but I do not remember who wrote it. The 302 is a good simple engine with lots of aftermarket parts and websites devoted to passing on helpful information. Good luck.
on
1 Post
302 heads on 289
The authers name is Tom Monroe. I ordered my copy from Amazon.com.
>of a good book on
>I loaned it to a
>Block but I do not
>Good luck.
Roger Lane
Test Analyst
Sr. Automated Test Engineer
IBP, Inc.
>of a good book on
>I loaned it to a
>Block but I do not
>Good luck.
Roger Lane
Test Analyst
IBP, Inc.
