302 vs. 289 heads
Old Nov 6, 2010 | 03:23 PM
dogstar's Avatar
dogstar
Question 302 vs. 289 heads
I just bought a used 302 but it has 289 heads. Why would someone put 289 heads on a 302?
Old Nov 6, 2010 | 03:30 PM
lew52's Avatar
lew52
The 289 , 302 , 351 , can all use the same heads , i have 351 heads on a 302 , but the 351 uses bigger head bolts ....Lew
Old Nov 6, 2010 | 03:38 PM
dogstar's Avatar
dogstar
But why use 289 heads, higher compression or what. what does the 289 heads have that 302 heads don't?
Old Nov 6, 2010 | 03:43 PM
lew52's Avatar
lew52
Depends on what year the heads are , The chamber cc , if you get a number off the heads & block someone hear can help you ....Lew
Old Nov 6, 2010 | 03:49 PM
dogstar's Avatar
dogstar
Its a '68 fairlane/torino 302 but i don't know where the numbers for the heads are.
Old Nov 6, 2010 | 03:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Casting numbers on engine blocks, cylinder heads cannot be cross referenced to Ford part numbers.
Both the 289 & 302 were used in 1968 Passenger Cars.
Old Nov 6, 2010 | 04:53 PM
DavidB's Avatar
DavidB
Smaller combustion chamber
Depending on which heads, the 289 heads are a bolt on change and generally offer a smaller combustion chamber and higher compression ratio. A little more power. Cheap "upgrade".
Old Nov 6, 2010 | 10:33 PM
Conanski's Avatar
Conanski
There is very little difference in any of the SBF cylinder heads, and IMO they're all WAY to freakin small for these motors.
Old Nov 7, 2010 | 05:34 AM
Greyf100's Avatar
Greyf100
http://www.carbdford.com/tech/flowdata.htm
Old Nov 7, 2010 | 08:49 AM
Old Hickory's Avatar
Old Hickory
289 and 302W heads are basically the same, valve sizes, port size etc. The only difference in the heads would be in the size of the combustion chamber. Most, but
not all 289 heads had small combustion chambers which help achieve more compression.
The 1968 302 4V heads also had small combustion chambers but the 2V heads had a
larger chamber for less compression.
Old Nov 7, 2010 | 08:04 PM
Greyf100's Avatar
Greyf100
i dont have 289 info..but...
302*/ 69-69 / C9ZE-A / 63CC / 2.23/1.71 BOSS 302
302*/ 70-70 / DOZE-A, D1ZE-A / 58CC / 2.19/1.71 BOSS 302
302 / 68-70 / C80E-F / 53.5CC / 1.78/1.45 Used on 4V Engines
302 / 68-70 / C7OE-C, G, C8AE-J, CE-F, C8OE-J, M, C8OE-K, L / 63CC / 1.78/1.45
302 / 68-70 / C9TE-C, DO0E-B / 58.2CC / 1.78/1.45
302 / 71-74 / D1TZ-A, D2OE-BA / 58.2 / 1.78/1.45
302 / 75-76 / D5OE-GA, -A3A, -A3B / 58.2CC / 1.78/1.45 First w/ Internal Air Injection Ports
302 / 77-77 / D7OE-DA / 69CC / 1.78/1.45
302 / 78-80 / D8OE-AB / 69CC / 1.78/1.45 Shared Application - 351W Stamped rockers
302 / 79-84 / D9AE-AA / 67.5-70CC / 1.78/1.46
302 / 85-85 / E5AE-CA / 67-70CC / 1.78/1.46
302 / 86-86 / E6AE-AA / 62-65CC / 1.78/1.46
302 / 87-93 / E5TE-PA, E7AE-AA / 62-65CC / 1.78/1.46
302 / 87-93 / E7TE-PA / 60-64CC / 1.78/1.46
302*/ 93-93 / F3ZE-AA / 60-63CC / 1.84/1.54 GT-40 Cobra
302*/ 94-95 / F4ZE-AA / 60-63CC / 1.84/1.54 GT-40 Cobra
302*/ 96-97 / F1ZE-AA / 63-66CC / 1.84/1.54 GT-40 Explorer
302*/ 97-00 / F77E-AA / 58-61CC / 1.84/1.46 GT-40P Explorer
351*/ 69-74 / C90E-B, D, DOOE-C, G, DOOZ-C / 60.4CC / 1.84/1.54 Offered highest HP rating in 1969
351 / 75-77 / D5TE-EB / 60.4CC / 1.84/1.54 First w/ Internal Air Injection Ports
351 / 78-80 / D8OE-AB / 69CC / 1.78/1.45 Shared Application - 302 Stamped rockers
351 / 85-86 / E5AE-CA / 67-70CC / 1.78/1.46
351 / 87-95 / E7TE-PA / 62-65CC / 1.78/1.46
Old Nov 8, 2010 | 12:27 AM
pcmenten's Avatar
pcmenten
How do you know the heads are 289 heads?
I have a pair of 66 289 heads with 54cc chambers, and pushrod slots. The small chambers will raise compression. They used to be the hot ticket for hopping up a Windsor. They can be machined for 1.90/1.54 valves.
Grey, it looks like there are some missing casting numbers such as the E6TE heads. Truck heads, I know, but you have included some truck heads in your listing.
Edit: D'oh! I know how you know they're 289 heads. They say 289 on the head!
Last edited by pcmenten; Nov 8, 2010 at 12:32 AM. Reason: Add information and ask a question.
Old Nov 8, 2010 | 04:57 AM
Greyf100's Avatar
Greyf100
in '66 they went to rail rockers, thermactor bumps, and round push rod holes.... everything i've read says '65 (C5) were the last year for push rod slots.
Old Nov 8, 2010 | 05:32 AM
NumberDummy
Originally Posted by Greyf100
302 / 68-70 / C7OE-C, G, C8AE-J, C8DE-F,
When you type 8 & D together, you get that smilie, unless you disable smilies in text (like I just did...it's gone).
Click Edit, then Go Advanced, then scroll down and click on the box next to: disable smilies.
Old Nov 8, 2010 | 10:28 AM
pcmenten's Avatar
pcmenten
