Sponsored by: Real Truck
Torque Specs?
Old Aug 30, 2002 | 09:48 PM
FortyFords's Avatar
FortyFords
Torque Specs?
Old Sep 17, 2002 | 03:14 AM
mikevollmer's Avatar
mikevollmer
Torque Specs?
Truck is a 2001 5.4L, 5-speed, 4x4 ...
What are the recommended torque ranges for
(1) Transmission (ZF 5-sp?) drain & fill plugs
(2) Transfer case (NV 271?) drain & fill plugs
Unfortunately there aren't any decent manuals available ...
Old Sep 17, 2002 | 03:36 AM
FortyFords's Avatar
FortyFords
Torque Specs?
There are manuals available Helminc.com (very pricey)
Maybe e-bay some guys get the cd
Now these #'s are for the zf 6spd
drain/fill 26 ft/lbs--35 nm
Transfercase 20ft/lbs --27 nm
These are for the zf- 6sp I only give you these as a reference.
I would stay less than these Just in case !
I don't want you breaking the case!
I will search for the 5 sp ones !
Rich
Old Sep 17, 2002 | 06:57 AM
Monsta's Avatar
Monsta
Sit. Stay.
Torque Specs?
44 lb. ft.
Old Sep 17, 2002 | 09:05 PM
4x4x4x4's Avatar
4x4x4x4
Torque Specs?
[updated:LAST EDITED ON 17-Sep-02 AT 10:06 PM (EST)]>>(1) Transmission (ZF 5-sp?) drain & fill plugs
>44 lb. ft.
That's a fair amount.In spite of what's recommended I personally wouldn't tighten it that tight.I would also use some thread sealant "dope".I've seen new transaxle cases crack at the drain plug area during assy.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
1978 - 1996 Big Bronco
May 25, 2002 03:08 PM
broom
Nov 24, 2001 12:46 PM
