glow plug question
Old Mar 21, 2010 | 03:15 PM
06yz125's Avatar
06yz125
glow plug question
I have to cycle the key five times when its cold (<45 degrees)
for it to start smoothly. As long as I do this it starts fine.
Any way to troubleshoot this problem? Or is there a cheap part
I could just throw at it? Like a relay, fuse or something.
Like to eliminate the easy stuff before dealer time.
Any input appreciated.
Thanks
Gary
Old Mar 21, 2010 | 03:30 PM
texans's Avatar
texans
you can ohm the plugs at the connector to check the glow plugs. I will see if I can dig up the post about checking the gp circuit. Mark has a good explanation on this.
Old Mar 21, 2010 | 03:35 PM
cheezit's Avatar
cheezit
ok check ficm voltage theres a number of post on this subject.
check the batteries, when doing so its important to isolate the grounds to each one
to test the glowplugs disconnect the buss bar and ohm from the componet side of the bar one pin at at time (4pins each side total) to ground, should be about an ohm. do not use a test light you wound get accurate readings.
Old Mar 21, 2010 | 03:41 PM
06yz125's Avatar
06yz125
Whats wierd is even when it was 10 degrees outside the glow plug lite only stayed on for 3-4 seconds. As long as I cycled it several times..
no problem.
My Dad had the same problem with a 7.3 a few years back and he replaced a "relay". Whatever that means. He said the dealer
did it so he can't help me find the issue.
I would think the lite should stay on longer in colder weather??
Old Mar 21, 2010 | 03:45 PM
texans's Avatar
texans
sorry double post
Old Mar 21, 2010 | 03:46 PM
texans's Avatar
texans
here is the post read number 11. by bismic https://www.ford-trucks.com/forums/9...g-failure.html
Old Mar 21, 2010 | 03:58 PM
bismic's Avatar
bismic
Cycling the key does nothing for the glow plugs - they are on for 2 minutes (no need for cycling the key). The plugs staying on and the light are not connected. Now the injectors may benefit from it. I would say check your batteries (load test individually), then check your FICM.
edit -
Darn it - just read Cheezit's post. Oh well ...... what he said!!!
(good post cheezit)
Old Mar 21, 2010 | 04:17 PM
06yz125's Avatar
06yz125
WOW, you guys are great.
I didn't know when the lite went out the plugs were still activated.
Thanks for all the info. The batteries are new so I can concentrate
on the FICM.
I'll also just wait for 30 seconds after the lite goes out when its cold.
Might just be my ignorance is part of the problem.
Thanks again
Gary
Old Mar 29, 2010 | 06:44 AM
msgtg's Avatar
msgtg
Gary,
I had a similar issue...I never cycled the key that many times but in my 03 if I tried to start it cold (without plugging it in) it ran like it was firing on half the cylinders...until it warmed up.
My mechanic (he's a certified Ford diesel tech) updated the flash on it...and I no longer have that issue.
BTW, I got your WV membership request...but I need some info from you. What's the best way to contact you? Once you get a few more posts under your belt, you could use the PM feature!
Joe
Old Mar 29, 2010 | 07:01 PM
06yz125's Avatar
06yz125
Hi Joe,
I ended up taking it to the dealer. They reprogrammed PCM and installed a new EGR. Works much better now. Only cost me $607.90...
My cell # is 304-646-7229. Thanks for the offer to contact me and your experiences. We just did the ball joints ourselves thanks to this great site.
Gary
Old Mar 29, 2010 | 08:44 PM
msgtg's Avatar
msgtg
Gary,
Shoot me an e-mail to msgtg@hotmail.com and put FTE in the subject line. I'll reply and give you the info that I'm asking for.
Joe
Old Mar 29, 2010 | 09:00 PM
adamtheman16's Avatar
adamtheman16
I've seen this problem with the F-650's with 6.0L in them. I work at an International dealer, so we can reprogram the 650s and 750s. The reprogram seems to take care of it.
DBANDGB
Jul 15, 2014 04:46 PM
panelguy
1997 - 2003 F150
Oct 8, 2006 11:54 PM
bocco
Aug 4, 2005 11:48 AM
glhoward
1983 - 2012 Ranger & B-Series
Oct 26, 2002 01:35 AM
gsruben
Aug 25, 2001 08:28 PM
