Is it normal for the engine RPM's to jump when shifting into park? The engine seems to lope along while in drive, but then when I shift into park, the RPM's skyrocket?
So, now for an update...
Monday- Installed new air cleaner, breather, radiator coolant, and raditator cap.
Tuesday - Began degreasing, and then despite my best effort, drowned the distributor.
Wednesday - experienced the first case of death wobble! Will be checking tie rod ends and wheel bearings tomorrow evening.
I am looking at the above picture, and I didnt realize the dealer mounted the AC compressor on its side rather then up and down with the dealer add on AC. I think that is the same compressor used in factory installed applications, but from the factory the fittings are on the top. Somebody correct me if I am wrong?
I have a 79 with dealer air addon,that looks like what you have,the evaporator box is behind the dash...and can be a pain to work on,but it does a good job when working
You know I was super happy to take that comp off my old truck but I'm thinking I might be really interested in havin' that big lump in the engine bay in my new truck here in a few months!
Triumph, I see you're in GA too. I was thinking the same thing, but the whole system looked to be in rough shape so it had to go.
The saga continues though, I drove her to work today, and she's spending the night. The alternator appears to have bit the dust! Can't go more than about 50' without a jump start lol. Gonna learn a lot from this one.
Jeepers, yeah, I'm in Athens, and sometimes Augusta on the weekends. Where are you at? As far as the Alt, I would check the fusible links that are somewhere around the starter solenoid on the pass side of the engine bay. I had that problem too, turns out the fuseable link was good but the wire broke where it was going into the link.
I work on Fort Gordon for a general contractor. Too embarrassed to say which (long story)
today, I determined that the alternator was good and battery is charging at advance auto as we speak. I believe I found the source of the power issue...The line that goes from the alternator to the battery was not connected to anything So I put that back on and we'll see if that does it.
I did discover that in the process of pushing the old girl off the street, I destroyed what was left of the rubber coupler disk on the steering column. So, I bought another one of those, and also bought the track bar bushing that I noticed was pooped out. I'll install those tomorrow and hopefully she'll be running strong again tomorrow.
Not to sky rocket but it will go up some when putting into park. posibble ret the idle jet lower
