leaking fuel
Old Mar 19, 2010 | 10:28 AM
clbostian's Avatar
clbostian
leaking fuel
i have fuel leaking down the back of my motor draining out of the drip pan between the motor and tranny. trying to see if anyone has had this problem before that can lead me to the source. thanks.
Old Mar 19, 2010 | 11:21 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
Get on top of the engine and use a flashlight to look down in the valley. Look for pools of fuel. I would start by checking the cap on the fuel filter, then check all the lines coming from the fuel bowl to the heads. Oil/fuel from the top of the engine will drain down the back of the engine and run out of the TC inspection plate. Let us know what you find.
Old Mar 19, 2010 | 11:49 AM
riverrat41's Avatar
riverrat41
Welcome....Rick has ya going in the right direction...Check the fuel drain lever on the fuel bowl.There is too fat orings in there that are known to leak.
Old Mar 19, 2010 | 08:46 PM
Doubleubar's Avatar
Doubleubar
If the fuel lines to the heads or the o-rings in the fuel drain valve are not leaking, also check where the fuel supply and return lines enter the fuel bowl on the drivers side of the fuel bowl.
I had a similar leak with the fuel collecting in the valley and draining out the back of the engine and it turned out to be a small hole in the fuel supply line about 1" from the fuel bowl.
Glenn
Old Mar 19, 2010 | 11:07 PM
mongo75's Avatar
mongo75
All leaks on this block run down the back LOL. Nothing I can add that won't ocver what's already been said, but I did wanna welcome ya to FTE!
Old Oct 10, 2010 | 11:09 AM
clbostian's Avatar
clbostian
Thanks
Thanks for all the help, it led me to my problem. It was the right side delivery line had a hole rubbed in it. Thank all for ur help.
jasen
19
Jun 19, 2014 08:59 PM
george horner
Apr 1, 2012 09:39 PM
mechelement
Nov 21, 2011 07:41 AM
przao1157
May 1, 2009 04:18 PM
wader200
General Diesel Discussion
Nov 27, 2006 03:15 PM
