Fuel is dripping out of a tube that's faced towards the ground at the front of the motor. Is this from the fuel bowl? Fuel bowl drain leak? It's cold out there now and I've never noticed it leaking like this before.
Your fuel drain valve is most likely leaking. As the temperatures drop they tend to leak. Check out the link below for rebuilding it with parts from Diesel O-Rings.com.
