looking for injectors
Old Mar 19, 2010 | 04:54 PM
rat49f6's Avatar
rat49f6
Originally Posted by PwerStroke99
Eh, Cass Injectors are ok. They only got 463hp on a stock HPOP and a 100hp tune. Thats up from 291 with stock injectors and a 120hp tune!
u went from 291 to 463 with no mods other than reburn and injectors???
Old Mar 19, 2010 | 05:08 PM
ron's power stroke's Avatar
ron's power stroke
now that would be nice...
he has a BB 38R and running 250 hybrids....im sure he has RR but if he did some more fuel work and add the Adrenaline he could be over the 500 mark...thats where ill be this time next year...right now the Adrenaline then a sump with 5/8 fuel lines pumped with a 41402 fuel lab is about to go on if i can get other chit done...
Old Mar 19, 2010 | 05:19 PM
PwerStroke99's Avatar
PwerStroke99
Oh yea, and a BTS.
So i installed, Injectors, BTS, and new tunes. I still have a RR to install
Old Mar 19, 2010 | 05:39 PM
cowboy69911's Avatar
cowboy69911
I had my injectors built by Electronic injection service out of OR they are great!!! Jon builds them and flow tests them all in house. He has all the equipment and has been doing it for years. his 75hp (stage 1) run $145 each if he can re-use your bodies if not then its $195 each for brand new ones. Here is his website. Diesel Fuel Injection, Diesel Repair Portland OR (Oregon) Chevy, Ford, VW, Dodge - EIS Diesel
Old Mar 21, 2010 | 08:37 PM
CSIPSD's Avatar
CSIPSD
I would not buy a doughnut from EIS... I PERSONALY know of 5 sets of there suppperduppper hybrid injectors that have been nothing more then junk. Putting out less then 160cc of fuel and bad or shimmed armitures...
BUYER BEWARE from ANYTHING from EIS... RUN AWAY!!!
Old Mar 21, 2010 | 09:22 PM
Izzy351's Avatar
Izzy351
And I went from 310 to 450 with a van turbo & Cass 235/100s...
Oh, and on a stock fuel pump & lines, fuel bowl, and just a Hutch & DFA RR. I have too much fuel & not enough air right now. And PMRs.
Old Mar 21, 2010 | 09:28 PM
Bigcat350's Avatar
Bigcat350
You want go wrong with Swamps injectors IMHO I have had 2 set and both did great.
Old Mar 21, 2010 | 09:31 PM
cowboy69911
Ya well I guess that is why mike has been in the top 5 at banks sled pull every time. He goes. When jon and patrick built his motor. They built my injectors and they flow tested 250cc and I put down 481 hp on the dyno. But hey whatever I have had no problems with them in the 3 years I have known them.
Old Mar 21, 2010 | 10:53 PM
cjfarm11's Avatar
cjfarm11
Just call clay a riff raff and get a set of stage1 single shots and letter rip. Like izzy said it might be a good idea to install a 1.0 exhaust housing to help control egt's.
Old Mar 22, 2010 | 04:11 AM
ron's power stroke
nice ##'s Joe....450 is about where you want to be careful with fuel..running them injectors out of fuel at them RPM's is not good for them..thats why im doing fuel mods first..then the big sticks..then again.. them #'s are not so good for them PMR's ether..glad she held up for ya..
Old Mar 22, 2010 | 08:45 AM
Izzy351's Avatar
Izzy351
I do have a bit of a pressure drop (I have a pressure gauge now), but it recovers after the initial hit. That will be fixed with the new pump. Roland (Muekster) had the same issue with his stage 2s, and fixed it with the Walbro GSL392, which is the same pump I'm putting on.
Old Mar 22, 2010 | 10:00 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
What pressures do you see when it drops and then levels out?
Old Mar 22, 2010 | 10:22 AM
  #28
CSIPSD's Avatar
CSIPSD
Banks pull huh...
When he can build a set of injectors that do not need shimmed, repaired, parts replaced or acually flow what he says they will... Then I will not have anything bad to say.
Like I said, 5 people in the oregon/washington area have been bit by him and his suppper injectors...
Old Mar 22, 2010 | 10:41 AM
  #29
Izzy351's Avatar
Izzy351
It drops to about 30 then pops back up...
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid370.photobucket.com/albums/oo148/Izzy351/Fuel%20System/FuelPressureDrop.flv">
Old Mar 22, 2010 | 07:53 PM
  #30
Stewart_H's Avatar
Stewart_H
You musta scared someone! In the vid, I can hear someone braking really hard for a split second, screeching their tires!
Stewart
DaytonaTunnel
Ford Truck Parts for Sale
Mar 22, 2014 09:19 AM
climber87
Bronco II
Jul 12, 2008 10:09 AM
superdutyaz
Sep 25, 2006 10:22 PM
chris12
Offroad & 4x4
Jan 27, 2006 05:03 PM
Stampede
Jun 25, 2004 10:11 PM
