Rear-end oil plug
Old Mar 17, 2010 | 04:53 PM
JHoffman93's Avatar
JHoffman93
Rear-end oil plug
Ok, I must be an idiot because I can not find the fill plug for the rear-end. I have a rear axle oil seal leaking and I need to add oil to the rear-end. I have looked all over the pumpkin and can't find it anywhere. Where is it located??? I have the parts to change the seals but I need to use the truck one more time tonight before I tear it apart. Thanks ahead of time.
Old Mar 17, 2010 | 05:28 PM
LCAM-01XA's Avatar
LCAM-01XA
It's on the driver-side of the pumpkin, in front of the axle tube and right about at the level of the axle shaft. It takes 3/8" square drive ratchet to remove it.
Old Mar 17, 2010 | 05:58 PM
JHoffman93's Avatar
JHoffman93
Thanks, found it. It was packed with dirt and hard to see even when I knew where to look.
r_reed
Aug 14, 2009 09:05 PM
Fordpup
Bronco II
16
Oct 24, 2007 11:42 PM
DGMFORD
Oct 6, 2007 08:56 PM
Reagan
1978 - 1996 Big Bronco
Jul 17, 2004 06:05 PM
hirschi
Mar 18, 2002 09:49 AM
