1978 - 1996 Big Bronco
pickup / bronco rear ends interchangeable ?
Old Jul 12, 2004 | 05:50 PM
Reagan's Avatar
Reagan
My rearend is going out on my 81 bronco. I am having a hard time finding one at a salvage yard , Will a rearend from a half ton pickup work ?
Old Jul 12, 2004 | 10:22 PM
GypsyR's Avatar
GypsyR
Yep. Make sure you get the same ratio, it has to match what's in your front end or it will a disaster as soon as you put it into 4wd.
If you have a 9 inch rear end now, make sure you get a 9 inch replacement. Later trucks and Broncos have 8.8 inch rear ends. You could use an 8.8, but you have to change more stuff than you'd think to make one fit. Not worth the trouble at all. I'm not sure when the 8.8's started being used, but I've personally yet to see a factory 9 inch in any truck/Bronco later than 1986.
Old Jul 13, 2004 | 09:47 AM
LEIGUY's Avatar
LEIGUY
it does not matter if the gearing is different...i just did this to my bronc....put a 10.25 in the rear with 411 gears and the front is 373 i think.....no 4wheel problems at all....
Old Jul 13, 2004 | 12:14 PM
dkaska77's Avatar
dkaska77
leiguy
Your gonna destroy your transfer case quick.
Ratios are to far apart.
Old Jul 13, 2004 | 12:39 PM
cryptonik420's Avatar
cryptonik420
I Agree! Get The Right Gears Or Get Tires On It That Will Make The Gearings Equal Out!
Old Jul 16, 2004 | 09:40 PM
bigric's Avatar
bigric
Reagan--any Ford 9" axle will work. They used them from the '60s until about '83.
Old Jul 16, 2004 | 10:53 PM
bossind's Avatar
bossind
Driveshaft angle may be differant. Pickup is much longer that the bronco, thus the angle would be differant. May need to shim it to get the right angle, other than that would be the same.
Old Jul 17, 2004 | 12:04 AM
burtoby's Avatar
burtoby
I swapped the rear out of a 94 half ton PU into my 90 Bronco. The 3.55 ratio was all I needed to worry about. My original got so noisy, I couldn't hear my radio. Ford is good about interchangability ( that's why they're so many of them. It keeps the cost down, compared to the competition).
Old Jul 17, 2004 | 06:05 PM
javi2001's Avatar
javi2001
Yeap angle is different BUT Bronco use a special angled spacer between axel and leaf springs to provide right angle for each application, just switch both rear axels and be sure you install the spacer.
ford351m
Aug 4, 2013 11:52 AM
J Hodges
May 10, 2008 10:43 PM
ryanfire12
Feb 9, 2005 05:41 PM
ish1940
1947 and Older Ford Trucks
Mar 5, 2003 11:50 AM
AlM
Oct 30, 2001 07:33 PM
