Strange "thump"
Old Mar 16, 2010 | 11:09 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Strange "thump"
Ok, my truck has 33,000 on it. When I start it, about 20 seconds later there is a "thump", like someone has thrown a ball or something at the back of the cab.
Something in the tranny? It's puzzling.
Any thoughts?
Old Mar 16, 2010 | 11:24 PM
liv's Avatar
liv
If it happens when you put it in gear its the slip joint
from the tech folder...
Slip joint regreasing
Old Mar 16, 2010 | 11:50 PM
amdriven2liv
Nope, just after starting, not moving any lever or releasing of brake pedal, just idling.
Old Mar 16, 2010 | 11:53 PM
liv's Avatar
liv
no idea
get under the truck and see where its coming from.
Old Mar 17, 2010 | 04:02 AM
Zip's Avatar
Zip
Sounds to me like it could be the blend door. Part of the interior climate control
Once vacuum builds up depending on where your dial is set it may close causing the thump.
If I'm not correct someone will let us know.
Old Mar 17, 2010 | 07:25 AM
teppler's Avatar
teppler
Mine does the same thing sometimes, always wondered but decided after 57,000 miles it must not be anything really bad.
Old Mar 17, 2010 | 11:42 AM
utjer's Avatar
utjer
It is the vacuum for the blend door. Mine does it every now and then also. It is nothing to worry about.
Old Mar 17, 2010 | 11:44 AM
cartmanea's Avatar
cartmanea
Yep, blend door. Mine is really loud sometimes and worried me at first. If you turn your fan to 'off' before shutting off I think it doesn't do it then. I hadn't noticed it for a while and it did it crazy loud yesterday and startled me.
Old Mar 17, 2010 | 11:54 AM
amdriven2liv
I figured I'd get an answer for this. This forum is great. Thanks for your help.
Old Mar 17, 2010 | 12:57 PM
ciscofreak's Avatar
ciscofreak
No kidding. It just started doing this again after over a year. I can actually feel it through the floorboards.
Old Mar 17, 2010 | 01:01 PM
lakewood's Avatar
lakewood
Ok, mine does the same thing. thought it was the a/c clutch at first because some days it sounds almost like a grinding, i knew it was the a/c but it still worked fine so i didnt really worry about.
ibo
Feb 14, 2011 12:24 PM
kystangbanger
Apr 7, 2009 08:47 AM
gregngrant
Jul 6, 2007 07:06 AM
Lil' Momma
Apr 22, 2007 02:39 PM
NeXtras
1997 - 2003 F150
Jan 25, 2007 06:27 PM
