Sponsored by: Real Truck
How to check a ICP sensor?
Old Mar 16, 2010 | 09:18 AM
EXCALIBURHAWK40's Avatar
EXCALIBURHAWK40
How can I check my ICP sensor on a 2000 7.3? I have read to un-plug it while it's running and if it dies it's bad and if it stays running the computer is compensating for it....are there any voltage readings or parameters I can monitor with a OBDII scanner or? Thanks for any info in advance, Fred
Old Mar 16, 2010 | 10:03 AM
Pocket's Avatar
Pocket
Don't unplug it while it's running. Unplug it and then start the truck. If it runs better than when it was plugged in, you have a bad ICP sensor.
You can monitor ICP, voltage, and IPR duty cycle with a Powerstroke compatible diagnostic tool. Generic OBDII scanners do NOT work on these trucks.
Old Mar 16, 2010 | 10:04 AM
Pocket's Avatar
Pocket
By the way, what problems are you having with the truck that would make you suspect a bad ICP sensor?
Old Mar 16, 2010 | 10:17 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I think you've got it backwards...
If it's running rough with the sensor plugged in, kill the engine, unplug it, fire it back up, and if it smoothes out, then that's your problem.
Old Mar 16, 2010 | 10:20 AM
Toreador_Diesel
Beat me to it Curtis...
If you know someone that has an SCT programmer, you can defnitely monitor the ICP as well as a few other PIDs using the Livelink software, a USB cable, and a laptop with Windows XP.
Old Mar 16, 2010 | 11:05 AM
EXCALIBURHAWK40
The engine I wouldn't say is running rough it is just boggy or sluggish to get rolling....the ICP connector is oily....I am told if and when they are oily they are bad.....I cleaned it drove 40 miles and it's oily again....Fred
Old Mar 16, 2010 | 11:53 AM
Toreador_Diesel
Head down to your dealer or Napa and get yourself a new sensor...
If you have time though, I'd get on ebaymotors as you'll get it much cheaper...
Old Mar 16, 2010 | 12:01 PM
EXCALIBURHAWK40
I am going to go ahead and get a new sensor.....as far as boost leaks when I scanned and got readings while driving it showed between 14 and 16# of boost, the truck is all stock except for the baldwin large round air filter and straight pipe, it may just be me but my 95 OBS that I traded in was more responsive, it may have been chipped or tuned I don't know as I bought it used also, just trying to make sure this 2000 is running correctly, I haven't done a fuel mileage check on it as the weather has been cold and figured I would wait until temps were better, I will do that check soon as temps are better now....above 50 lately so I should do that...fred
cmypowerstroke
Aug 21, 2016 09:32 AM
roundmandt
Aug 5, 2016 04:00 PM
Kowdog
45
Jan 8, 2014 12:07 PM
gamaliel
Jan 7, 2013 08:33 AM
edub32
25
Feb 20, 2009 05:51 PM
