Pulling upper intake off Egr
Old Mar 15, 2010 | 08:43 PM
timellis's Avatar
timellis
Smile Pulling upper intake off Egr
Hey guys, I'm trying to pull my upper intake of my 98 Ranger 4.0l 4x4 so i can replace my valve cover and plenum gaskets. I have a nasty oil leak that smells things up from oil on the exhaust and I keep getting the 171 and or 174 codes every few hundred miles. I cant seem to pull the plenum up off the large egr line, how do I get the egr to come off so I can pull the plenum up???
Old Mar 15, 2010 | 09:33 PM
Rockledge's Avatar
Rockledge
Twist, turn, pull, and finagle. See: Ford Truck Enthusiasts Forums - View Single Post - Coolant Loss - 4.0L OHV Lower Intake Gasket
Old Mar 16, 2010 | 08:38 AM
timellis's Avatar
timellis
The problem with twisting is the studs for the plenum limit movement to about half an inch. I guess I'll try to remove the studs first ti see if that gives me some free play, thanx
Old Mar 16, 2010 | 10:13 AM
timellis's Avatar
timellis
You are not gonna believe this, but I finally got the plenum off by using PB BLASTER squirting it at the EGR in the plenum , and rocking, pulling swearing, misc. But the part you wont believe is... there was NO plenum gasket in there! Gee, I wonder if that might cause an air leak and set off a code? Somebody must have taken the plenum off and put it on without a gasket. I've only owned the truck for a month or so, but I've towed my 3300 lb mustang on a flat bed twice! Seemed to run ok, sometimes a little miss at idle, but the CEL only came on after 100 to 500 miles after resetting it. If I can I'll post pics of the intake and plenum, Tim
Old Mar 16, 2010 | 10:14 AM
timellis's Avatar
timellis
And by the way, You can't remove the studs before you remove the plenum, dumb in my opinion.
ZenLobo
1997 - 2003 F150
May 20, 2013 11:00 AM
Onus
Jul 3, 2012 07:40 AM
lmd91343
Feb 26, 2008 08:53 AM
fishin machine
1978 - 1996 Big Bronco
Jun 15, 2007 09:26 AM
JohnMMena
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 18, 2005 10:09 AM
