How do I remove the EGR->Intake Pipe?
Old Jun 17, 2005 | 07:28 PM
JohnMMena's Avatar
JohnMMena
I am working on a 98 Explorer w/ a 4.0L V6 OHV. There is a pipe that runs from the EGR to the upper intake plenum. I can't find a way to remove it from the block so I can pull it out of the plenum. I have already removed the EGR valve and the only bolt I see that could possibly be holding it on is the one that holds down the oil dipstick tubing. Is the plenum just supposed to pull up, allowing that pipe to slide out? I've tried this many times, but it appears to be tied down by the tube. I looked in the throttle body and saw that the pipe comes up and curves toward the front of the vehicle inside of the plenum. Is this the same piece I see coming in from the EGR or is it just an attachment to the hole that the EGR pipe runs into? Perhaps I overlooked something in that general area.
I'm working on a head gasket replacement which I need to finish off tonight so any help would be greatly appreciated!
Thanks,
John
Old Jun 18, 2005 | 10:09 AM
JohnMMena's Avatar
JohnMMena
Nevermind, I figured it out. I had to bend back the upper brace of the dipstick to access the bolt down below to remove the bracket.
Cardinal
Oct 27, 2024 11:23 PM
ExPACamper
28
May 12, 2017 11:31 AM
lee00
13
Oct 29, 2015 06:29 PM
Steve in NC
Jul 30, 2014 05:29 AM
kefrko
26
Apr 20, 2014 10:32 PM
