upper intake plenum 351w
Old Jul 2, 2012 | 08:53 AM
Onus's Avatar
Onus
Anyone know the torx bit size? Hopefully i can still get it out. My friend used the wrong sized and stripped out a lot of the bolt. It looks to be a t35?
It doesn't seem to be any size i have. Also why the heck do they put it in the hardest spot to get? I'm trying to pull it off to sell. Luckily the guy is in no rush to get the plenum.
Old Jul 2, 2012 | 09:02 AM
Conanski's Avatar
Conanski
It's a T40 Torx and it has to be on a 1/4 drive with a 6" extension.
Old Jul 2, 2012 | 09:47 AM
Onus's Avatar
Onus
Thanks a ton. I'll be picking up that bit then.
Old Jul 3, 2012 | 07:15 AM
baddad457's Avatar
baddad457
If you want to avoid this happening in the future, just leave that bolt out when you put it back together. It's not really needed as long as you have the other 5 bolts in and torqued to spec.
Old Jul 3, 2012 | 07:40 AM
Conanski's Avatar
Conanski
Another suggestion... take a die grinder or dremmel tool and remove the casting ridges around the runner split to make getting the bolt in and out much easier.
fmc400
Jan 22, 2025 09:19 PM
emkay4597
Jun 29, 2011 02:28 AM
greybullit
Dec 2, 2005 03:53 PM
JSPajak
Oct 29, 2005 04:22 PM
