Still Looking for a Radiator for my 49
on
After the deal fell through on the truck radiator I decided to go with a 68-70 Mustang three row radiator for a 390 engine. I'm picking it up at NAPA later this week. The price was right at $194 and it's an easy radiator to find most anywhere. It's a little shorter and a little narrower than the truck radiator and should be a bit easier to install. I'll get back here after I have it in my hands with exact measurements for anyone who might be interested. I'm sure the 73-77 F-150 radiator would also have worked and thanks to Tim for the pictures...
on
I surely would. You know my E-mail address! The 68-70 should all be the same...maybe even 67-70 for the big block engine. Mine has to be for the big block (390, 427, 428) since the small blocks (289, 302, 351) of those years had the bottom inlet on the passenger side and I need the bottom inlet on the driver's side...
on
Thanks, but what you have done is exactly what I'm trying to avoid. I don't mind fabricating the brackets to install the radiator into the stock radiator support but I do not want to build a new support just to make a Bronco or some other radiator fit. I appreciate the work you did and you did a great job but I think there is a simpler way to go and that's what I'm after. The Mustang radiator should fit right into the stock radiator support with little modification...
on
I picked up my new radiator from NAPA this morning. The 68 Mustang 3-row for a 390 is about 22 inches tall including the top tank, the bottom hose inlet (1 3/4 diameter) is on the driver's side, and the top outlet (1 1/2 inch diameter) is on the passenger side which is what I need for my 85 Ford 302. The entire width inchuding the brackets is 25 3/8 inches. Since the distance between the original radiator mounting bolts is 24 inches and the total width of the radiator support is over 25 inches it should be just a matter of drilling new holes for mounting. I'll try to take pictures of the mounting when I get around to it and post them here.
Thanks to all who helped me determine which radiator I needed...
on
Well the 68 Mustang radiator didn't work out after all so I'm still looking for a radiator. The biggest problem was that the lower inlet was positioned toward the center of the bottom tank instead of the far left as you would expect. I had to mount it higher in the radiator support due to the width and that brought the inlet above the bottom of the power steering pump making lower hose mounting impossible. I'll need something narrower and with the bottom left inlet further to the left...
on
After reviewing the radiator situation again this morning I've come to the conclusion that I may have the engine mounted too low. Regardless of what radiator I use it appears that I am going to have a clearance problem with the PS pump and fan clearing the lower hose. I see another topic coming called how high is your 302 mounted...or something like that!
rustyranger390
08-14-2011 01:24 PM
dutchlincoln79
05-25-2008 11:31 AM
JTdesert
13
08-09-2004 12:49 PM
