No door remotes or keypad code?? Can I get them?
Old Mar 11, 2010 | 07:58 AM
JoeDirt68's Avatar
JoeDirt68
Just got the truck. I got one key and no remotes.
The truck has the drivers key pad, how do I get the code?
Since there are no locks on the passengers side I have to unlock the drivers side and then go back around to let my wife in....not fun!!!
So I guess I have two issues:
Can I get the factory code for the key pad?
Can I get new remotes and program them to work?
Old Mar 11, 2010 | 08:02 AM
Jigger2020's Avatar
Jigger2020
look in there with your owners manual there should be a card in it with the # on it,or you can reprogram the code so previous owners cant get in,Gerry Yes you can program new remotes
Old Mar 11, 2010 | 08:21 AM
kailor's Avatar
kailor
Follow the driver's kick panel up underneath the dash and you should see a five digit number on (a yellow sticker) the lid of a plastic box.
Old Mar 11, 2010 | 12:36 PM
pdqford's Avatar
pdqford
Prolly depending on the year of his vehicle.
Do a search and you will find out when they changed the location of the code.
Old Mar 12, 2010 | 11:41 AM
KeystoneHomeOK's Avatar
KeystoneHomeOK
Programming the remotes (got mine off of eBay for 14.00 for 2) was easy and took me about 5 minutes. I just sat in the driver's seat and turned the key on and off 7 times and pressed the unlock button and it was programmed. The directions were in the packaging with the remotes.
Good luck!
Old Mar 12, 2010 | 02:28 PM
Oldtrucknut7077's Avatar
Oldtrucknut7077
Here is a link I used for an Explorer for the door code. You just change the wording for the Expy.
WikiAnswers - How do you reset the keyless entry on a 2004 Ford Explorer
As for spare keys/fobs, ebay... like evrybody else said.
Old Mar 13, 2010 | 06:59 AM
JoeDirt68's Avatar
JoeDirt68
Thanks all!
Old Mar 15, 2010 | 09:58 AM
JoeDirt68's Avatar
JoeDirt68
You sir are correct!!! Found it! Thanks Big help!!!
Also ordered a new remote and a spare key....gotta love eBay!!!
Old Mar 15, 2010 | 04:29 PM
thecardoc's Avatar
thecardoc
This code will allow you access and also will let you set a new code of your own . However that code on that sticker is Not changeable . If PO knows that # they still have access forever.
Lemming
Electrical Systems/Wiring
Aug 28, 2014 02:55 PM
300sflyer
Oct 27, 2012 02:41 PM
DWolf
Sep 17, 2003 09:12 PM
davidpoe
Jan 10, 2002 12:27 PM
