Sponsored by: Real Truck
Shocks & Confusion
Old Jan 22, 2003 | 09:18 PM
penguin149's Avatar
penguin149
Question Shocks & Confusion
I'm ready to replace the stock shocks on my 2001 F250 SD V10 Extended cab. I tow an 8000# travel trailer on occasions and don't want to do anything to hurt the towing of my truck but wouldn't mind helping the ride a bit, if possible. Searching through Bilsteins, Edelbrock & Rancho shocks, I am thoroughly confused. My truck is a 2WD, stock height with the 265 tires, my idea of off-roading is pulling onto the grass to wash the truck!; what shock would be best for my situation? Manufacturer? Model? etc?
Thanks,
Jim
Old Jan 22, 2003 | 10:05 PM
Outpost22's Avatar
Outpost22
Shocks & Confusion
All those you mentioned are good. If you think you need an ADJUSTABLE ride, your best choice is Rancho. Mine work great. Bilstein would be my next choice.
Old Jan 23, 2003 | 03:44 PM
gotv10's Avatar
gotv10
Shocks & Confusion
I replaced the stock shocks with Edlebrock IAS. They really made a big difference. I pull a travel trailer about the same weight as yours. Improved the loaded & solo ride.
Old Jan 23, 2003 | 08:11 PM
jetjock16's Avatar
jetjock16
Shocks & Confusion
Bilstiens and Edlebrock are gas shocks, most Rancho's are oil, uness you get the nitrogen shocks, gas is more expensive but much better ride than oil, the bilstiens are most expensive of the ones you listed but also superior, id recomend against Rancho
Jetjock16.
Old Jan 23, 2003 | 08:20 PM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
Shocks & Confusion
What jetjock said -- this guy knows what he's talking 'bout.
With the exception of the adjustable ride Rancho's, the Bilsteins are the tops. I don't know about you, but I'd rather save the $$$ from the adjustable Ranchos, buy the Bilsteins & re-invest the $$$ I saved in other mods. If you do some shopping around, you can pick up the Bilsteins at a pretty good price -- not too much more than their relatively "inferior" comparable makes.
Old Jan 23, 2003 | 08:23 PM
johnsdiesel's Avatar
johnsdiesel
Shocks & Confusion
Jetjock16.
The latest Rancho 9000 series shocks are more expensive than Bilstein. The best price I found for the Rancho is $79 each. I recently bought Bilsteins from Autozone for around $50 each and they are great.
Old Jan 23, 2003 | 08:29 PM
haroutd's Avatar
haroutd
Shocks & Confusion
You're talking about the 9000X, I assume? These are the adjustable ride shocks. In the end, they cost a whole lot more than that with the in-cab controller. I know you can run them without the in-cab, but who wants to pull over, dig into their wheel well and start adjusting 4 shocks, one at a time, to change their ride. Can't really compare these with the others on Jetjock's list as it's a "different animal".
Old Jan 24, 2003 | 11:35 AM
warmdye's Avatar
warmdye
Shocks & Confusion
My rancho rsx's treat me right.
Old Jan 24, 2003 | 03:14 PM
bddo's Avatar
bddo
Shocks & Confusion
The fact is that for every person on here that likes Bilsteins, there is someone else that likes Rancho. It seems to be split pretty evenly.. I just put the Rancho 9000x's on my SD, and I love the improved ride, both empty and hauling my trailer. I do plan on adding the in cab controller, but the reality is that you don't change the settings that often, so the 45 seconds that it takes to go around the truck and change them manually really isn't a big deal...
But....that's just my opinion!!!!
Old Jan 24, 2003 | 03:33 PM
203008581's Avatar
203008581
Hey Johnsdiesel, how recently did you purchase your shocks. Which model/series did you get. I like the sound of the $50 buck price. Were they on sale? Thanks.
Old Jan 24, 2003 | 03:42 PM
haroutd's Avatar
haroutd
Shocks & Confusion
If that's the price for the BE5-2818 and BE5-2819 shocks, COUNT ME IN! That sounds too good to be true... maybe I'll buy some extras & sell them on eBay!
Old Jan 24, 2003 | 04:29 PM
birdman127's Avatar
birdman127
Thumbs up Shocks & Confusion
I just got my Rancho 9000x"s fromSams Offroad .
$69.95 a piece or $279.80 with free shipping for four. A great price for a great shock
Scott
Old Jan 24, 2003 | 04:40 PM
superdutyspv's Avatar
superdutyspv
Shocks & Confusion
I love my Edlebrocks IAS on my 2000 F-250 SD, SC,LB,4x4,ORP,V-10. I put them on my truck and then drove 2000 miles; they are fantastic!!! I would have these on any truck I ever owned!!
Old Jan 24, 2003 | 05:20 PM
Yeti's Avatar
Yeti
Shocks & Confusion
Here is a set of used 9000's ones on evilbay:
Rancho 9000s
Old Jan 25, 2003 | 11:51 PM
charlesvalentine's Avatar
charlesvalentine
Shocks & Confusion
Wow, nobody mention KYBs I put KYB MonoMaxs on my 4x2 f250 and they eliminated the bump steer problems I was having as well as improved the ride. They are a great inexpensive and durable shock. I've put 30+k miles on em' and they are still working great. I do have one word of advice on the 4x2 installation though. BE CAREFULL when torqueing the nut on the lower shock bolt! I was using a torque wrench and the darn thing snapped off at half spec! The lower shock bolt is welded in and not available seperately from Ford so I had to replace the ENTIRE radius arm. To the tune of $93+tax. So my advise is locktite and just snug enough to keep the nut from backing off too easy.
Kalabin
Feb 16, 2015 03:48 PM
moto vita
Nov 22, 2013 01:14 PM
RedBoat
6.7L Power Stroke Diesel
32
Apr 2, 2012 02:19 PM
danocross
Jul 15, 2008 01:43 PM
gworks
Feb 12, 2008 12:17 AM
