Shock Opinions
Old Mar 14, 2012 | 08:50 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Shock Opinions
Ok I have read all the shock threads and am more confused than ever.
I want to replace the stock Ranchos with either Rancho 9000XL's or Bilsteins. I put Bilsteins in the 2003 (2wd) and it made it ride like a dump truck great shocks just a very harsh ride. I would like to keep the comfortable ride. Has anyone here tried the Rancho 7000MT's? I am kind of leaning toward the 9000's so I can tune the ride with the flip of a switch? So those of yall with Bilsteins and the Ranchos can you give me some pro's and cons of them?
Old Mar 14, 2012 | 10:01 PM
jmcquarry's Avatar
jmcquarry
I have been told they are both great shocks, huge upgrade. I opted for the Bilstein 5100's and never looked back. I have a hard time putting Rancho's back on the truck, maybe silly but the sub par shock with their name on it that was stock (FX4 upgrade) left a nasty taste in my mouth. I am sure 9000xl's are a good shock, trust those who have installed them and reccommend them. Just a matter of preference...........After 5000k miles the Bilsteins are performing flawlessly,,,,but I can't adjust them on the fly,,,,,the ride does not seem rough,
Old Mar 14, 2012 | 10:37 PM
Glockin' Bob's Avatar
Glockin' Bob
That's pretty impressive, 5 million miles!!
Old Mar 14, 2012 | 11:12 PM
Beechkid's Avatar
Beechkid
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications. If you are running very stiff tires on the street (such as Bridgstone that are 100% steel belted or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street (such as BFG that are a mix of steel & nylon belted or tires with profiles not shorter than 50 series), these provide the extra stiffness that you need for both comfort & stability. The Exel-G’s (formerly GR-2) are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units.. Best shock for the $/best price typically found at Performance Suspension Technologies (PST) and typically about 1/3 less than Bilstein.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
Old Mar 15, 2012 | 12:23 PM
darren32's Avatar
darren32
If I had to choose between Rancho and Bilstein, I would go Bilstein 100% because of this exact reason stated by jmcquarry.
Thanks
Old Mar 15, 2012 | 03:14 PM
jlalanas's Avatar
jlalanas
I have a set of lightly used (maybe 15k easy miles) 9000s I could sell cheap, if someone wanted to give them a try.
Old Mar 15, 2012 | 04:32 PM
EpicCowlick's Avatar
EpicCowlick
I put the Ranchos on because I have used them before with great success. The FX4 shocks were really terrible and it just didn't make sense. Whatever excuse they come up with, the fact remains that Rancho made a huge mistake manufacturing those and putting their name on them. I have never used Bilsteins before so I can't speak to those but I can say with confidence that the 9000s work as expected. I love the ability to tune them as needed. I set them to 6 up front and 3 in back when unloaded. When towing, I just change the back shocks to 9 and leave the fronts alone.
Old Mar 15, 2012 | 04:45 PM
FishingNut's Avatar
FishingNut
x2 - only difference was it was a 2004 2500HD, but the 9000's were great, and I plan to upgrade mine before the $100 offer expires
BTW - The stock shocks were crap on that truck too, only lasted about 18 months.
Old Mar 15, 2012 | 05:38 PM
slowmans's Avatar
slowmans
I have the 5100's and they are great, no complaints here!
Old Mar 15, 2012 | 06:20 PM
jmcquarry's Avatar
jmcquarry
Opps,
Old Mar 15, 2012 | 06:53 PM
KC8QVO's Avatar
KC8QVO
You have probably all read my thread by now too on the Rancho 9000's with MyRide. About all I will say here is the ability to adjust the shocks is what sold me on them. Without adjusting the shocks and tuning to what you prefer, how do you know what your ride quality is? The MyRide system is nice to be able to play with the adjustments without stopping, getting under the truck, and trying it again. Adjusting the shocks defines the ride quality - you can put it on both sides of the spectrum and adjust to what you want. Fixed shocks won't ever give you that.
Old Mar 15, 2012 | 08:21 PM
Dim Sum's Avatar
Dim Sum
I just let Steve tell me which settings are best for my 9000XL's.
I like that I can change them when I'm towing and change them when the load is off the back of the truck. Fixin' to turn them up for the tow out to Vegas.
Old Mar 15, 2012 | 09:21 PM
MR.DAVE's Avatar
MR.DAVE
I have a 2011 f-350 sd , truck has the camper package,I installed the Bilsteins (5100) and my truck rides too stiff now,when on the freeway and I come in contact with some uneven pavement the front end of the truck bounces and the rear also bounces. I do not like the ride at all.I will be installing the Rancho 9000s and then I will be able to tell you which is better first hand. I will be selling the Bilsteins if anyone is interested.
Old Mar 15, 2012 | 09:45 PM
TreverAdamo's Avatar
TreverAdamo
[quote=RedBoat;11575138]Ok I have read all the shock threads and am more confused than ever.
I want to replace the stock Ranchos with either Rancho 9000XL's or Bilsteins. I put Bilsteins in the 2003 (2wd) and it made it ride like a dump truck great shocks just a very harsh ride. I would like to keep the comfortable ride. Has anyone here tried the Rancho 7000MT's? I am kind of leaning toward the 9000's so I can tune the ride with the flip of a switch? So those of yall with Bilsteins and the Ranchos can you give me some pro's and cons of them? [/quote
On my 08 fx4 I just wanted something different. So i started with the bilsteins and i felt the same as you do that they rode way to stiff so i took them back and went with the rancho 9000's And out of the 2 i feal the rancho is the way to go. They ride so much nicer then the bilstines did and like you say they can be set to how you want. But if you relly want the bilsteins and they are nice, you can have them revalved buy bilstein to how you want them. But that is $65 per shock. You can go what ever way but for sure the rancho's will give a smoother ride out of the box.
Old Mar 16, 2012 | 07:32 AM
SavageNFS's Avatar
SavageNFS
So it sounds like my truck is going to need new shocks soon...great!
