Sponsored by: Real Truck
P0135, P0155
Old Mar 4, 2010 | 08:13 PM
mcdiver's Avatar
mcdiver
P0135, P0155
I have seen another message about this on an Excursion. But I am looking for some specific info on my truck if anyone can help.
I have a 2003 F-250 Super Duty 4x2 with the 5.4.
I started the truck the other day and the check engine light came on, when I checked the codes, both of these came up for the o2 sensors on bank 1 and bank 2. It has been suggested that I check the fuse for the ho2, but I was not able to find it in the manual. I checked all data online and found what I think is the fuse, but it is not blown.
I have never known 2 o2 sensors to go bad at once, this is a little confusing for me, any help?
Mike
Old Mar 4, 2010 | 10:17 PM
superdutyduck's Avatar
superdutyduck
when i had my explorer it threw the bank 1 code. i replaced it and then it threw the bank 2 code. might as well change both if you the opportunity to.
Old Mar 5, 2010 | 01:27 AM
redford's Avatar
redford
FTE Leadership Emeritus
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
Have you looked at the O2 sensor heater circuit?
Old Mar 5, 2010 | 07:10 AM
mcdiver's Avatar
mcdiver
I have tried to check the heater circuit; however, as I said, I am having trouble finding the correct fuse for it. The fuse I think it is, is not blown.
Old Mar 5, 2010 | 07:28 AM
GUNNERDOG's Avatar
GUNNERDOG
anytime more than one thing fails at the same time, and fuses all check good, i start checking grounds. O2 heater ground? (im just guessing here, not real familiar with the O2 system.) Ill take a look in my shop manual for ya when i get home tonight.
Old Mar 5, 2010 | 07:39 AM
mcdiver's Avatar
mcdiver
Old Mar 6, 2010 | 08:26 AM
mcdiver's Avatar
mcdiver
Really amazed that I got more help from a chevy forum then I did here.
Old Sep 15, 2011 | 06:54 AM
ken kenmnedy's Avatar
ken kenmnedy
Originally Posted by jbellows
LOOKS LIKE YOUR AT THE WRONG FORUM THEN
dont make em mad and run him off I want to see the fix here...
Old Sep 15, 2011 | 01:24 PM
twall_SD250's Avatar
twall_SD250
hey mcdiver did you ever find out what was causing the codes to come up.. i have the same 2 codes coming up on my truck
Grayson2120
2004 - 2008 F150
Nov 6, 2024 05:04 PM
cworthington
Jan 22, 2016 04:40 PM
breeaad
Jul 10, 2012 09:02 AM
Osideboy
1997 - 2003 F150
May 17, 2012 07:51 PM
cubaranger
Apr 6, 2010 10:02 PM
