HELP!!!! Loose axle!
Old Jan 21, 2003 | 04:28 PM
wildjon300ci's Avatar
wildjon300ci
Exclamation HELP!!!! Loose axle!
Help, this is driving me nuts. I need my truck up and running ASAP because I have no other form of transportation. I have the 8.8 in my truck with the notorious C-clips. The problem is that when the axle is installed, it give me LOTS of side to side movement. I found this out after the C-clip decided to work it's way out going down the road and the axle almost came out of the truck. I pulled the axle and the bearing is fine, so I think. No burn marks or wear compaired to the new bearing and it still turns freely. What could be causing my axle to do this? I have to make due with this axle until I can fork over the money for a 9" to put in the rear.
Old Jan 21, 2003 | 06:03 PM
FortyFords's Avatar
FortyFords
In the 8.8 's aren't there o-rings in where the c-clips are to keep them from walking ?
This is on your tuck in your sig ?
also if this 8.8 has never been rebuilt ,you may need new spiders in there in between the spiders and the spool are slip type bearings they wear out
Did you do and end play measurement ?
Are you having any leakage problems around your axle seals?
Rich
Old Jan 21, 2003 | 06:17 PM
wildjon300ci
I'm not sure about the O-rings...but this is the truck in my signature. No leakage proplems and when installed, I have 3/8" of side to side movement (endplay?) The spider gears look clean and they had no play. Should I go ahead and replace the bearing anyways. The axle doesn't budge up and down and I'd hate to ruin a perfectlly good bearing and oil seal (pretty 'spensive)getting them out. Thanks for the reply.
northwindone
Nov 8, 2011 06:19 PM
dumbear33
1978 - 1996 Big Bronco
Jan 3, 2010 12:24 PM
wildjon300ci
Jan 28, 2003 08:12 AM
wildjon300ci
Jan 22, 2003 05:15 PM
