Gas pedal issue/recall
Old Feb 28, 2010 | 03:37 PM
regidog's Avatar
regidog
1992 F350 7.3 4wd. When I start the truck and let it idle it runs at around 600-700 rpm (just like it should), but after I press the gas pedal it will hold the idle at 900-1000 rpm (too high). When I shut the truck off the gas pedal pops back up as if its been held down. I think the cruise control (which does not work) has something to do with this, as once the truck is turned off it immediately snaps back to original position, any ideas?
Also I udnerstand there was a recall on this years cruise control. My horn does not work and I believe that is a symptom of the recall, does any have any info on this? thanks
Old Feb 28, 2010 | 03:48 PM
JHoffman93's Avatar
JHoffman93
If the truck is cold (first start of the day) when this happens it may be your fast idle solenoid. Once the truck is warmed up it will kick the idle back down to 600-700 rpm. The solenoid isn't strong enough to pull the throttle cable on its own but it is strong enough to hold it in fast idle once you press the go pedal. If this only happens when it is cold and it goes away once it warms up this is normal and it is doing its job.
Old Feb 28, 2010 | 03:57 PM
regidog's Avatar
regidog
You may be right as it happened after the truck had been running for ten minutes or so.
Pipeliner_86
Dec 3, 2015 07:01 AM
gdubia
1997 - 2003 F150
Sep 21, 2011 06:17 PM
KGB
May 16, 2008 06:56 AM
joeyj
Jul 16, 2007 07:59 AM
maticuno
1983 - 2012 Ranger & B-Series
Dec 4, 2003 11:13 PM
