leaky slave cylinder... again
Old Feb 27, 2010 | 05:44 AM
84 f250 6.9's Avatar
84 f250 6.9
Cool leaky slave cylinder... again
I JUST replaced the slave cyl on my t19 bout 2 months ago and its leaking now grrrrr. Its warrantied but it broke at 5 am right when i went to start plowin , had to use the freaking snow blower again in the back of a chevy. This cant happen again , any tips on how to prevent this again? I had to put the tcase in neutral put the trans in gear and put the t case back in 4hi to get back up to the house i didnt like doing that at all
Old Feb 27, 2010 | 10:03 AM
starmilt's Avatar
starmilt
When that happens don't jam it in gear. Kill the motor and put it in granny and start it in gear. When my slave cylinder broke I was 250 miles from home, and when my bellhoising cracked I had to drice it over a month before I could take the time to fix it.
Old Feb 27, 2010 | 10:12 AM
84 f250 6.9
didnt even think bout trying that star .. it wasnt too bad cause I was rolling a little bit and only stuck it in 1st right ?
Old Feb 27, 2010 | 10:41 AM
starmilt's Avatar
starmilt
Yep if it will roll a little you can slip it in gear without grinding or jearking it, just let it kinda suck it in.
Old Feb 28, 2010 | 01:00 PM
84 f250 6.9
what about floatin gears ? will that destroy my trany ?
Old Feb 28, 2010 | 01:04 PM
starmilt's Avatar
starmilt
LOL that depends on you. I have done it for years with no ill affects, but grew up doing it too.
Old Feb 28, 2010 | 01:41 PM
84 f250 6.9
well i dont have a tach or any experience lol .. so i thought bout waitin til a synchro breaks then start floatin em .. cause plowlin snow im pumpin my clutch ALOT im sure thats wut happened to the slave cyl .. that and cheap quality
Old Feb 28, 2010 | 01:47 PM
starmilt's Avatar
starmilt
Plowing snow there is no way to not be using your clutch a lot, nowhere here you would be or even could be floating gears. On the road is the only place you could get away with it.
Old Feb 28, 2010 | 02:03 PM
84 f250 6.9
thats what I meant on the road haha I might not know everything but im not THAT dumb
Old Feb 28, 2010 | 02:11 PM
starmilt's Avatar
starmilt
I know of some that were converted and use the old style linkage, and I may even try this on my highboy, but I think it will be hard to push and maybe even wear the linkage worse than the hydraulic setup.
Old Feb 28, 2010 | 04:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Right now we have an 84 Dodge plow truck with the mechanical linkage.
With the snows we have been having, lots of problems with that linkage when you torque the engine.
That truck has a 360, so not even close to diesel torque.
The way parts are made these days, have a spare.
|WYG|SS
Nov 16, 2015 06:54 PM
jkschneider
21
Jan 25, 2013 12:42 AM
1994F2507.3L
May 10, 2012 04:49 PM
reddogracing
Aug 23, 2004 11:31 PM
tony1307
1983 - 2012 Ranger & B-Series
Nov 25, 2003 08:31 PM
