Sponsored by: Auxito
quick question on dash cluster
Old Feb 28, 2010 | 01:06 PM
Supermarkers's Avatar
Supermarkers
Got my 99 f150 4.6L
Has the basic cluster.... no tach. (digital odometer)
I would like to get a cluster with a tach from another f150/expedition.
Can i plug it in and away you go?
or
Do I have to get it programmed at all?
Thanks
Mark
Old Feb 28, 2010 | 01:44 PM
93 mix 'n match's Avatar
93 mix 'n match
i dont think there would be a wire for the rpm sensor there so you probably would need one of those.
other then that, it should all just plug in.
kudos on not putting a big rice tach in like some people.
Old Feb 28, 2010 | 01:47 PM
Supermarkers
bahaha rice tach!!!
well I had a 1990 f150, has the basic cluster, i got one with the tach from the wreckin yard, plugged everything in, snapped the spedo cable on, and everything worked, tach and all.
I think the wire is already there, its just there is no tach at all on the dash.
Kinda like there is a harness near my sway bar that is for fog lights that i will be puttin on soon too!
Old Feb 28, 2010 | 01:51 PM
93 mix 'n match
well then it should all plug right in.
Old Feb 28, 2010 | 01:55 PM
antony25's Avatar
antony25
The PATS module is the cluster. The cluster will need to be programed to the vehicle and your keys.
Old Feb 28, 2010 | 02:18 PM
highteckredneck's Avatar
highteckredneck
he is right, you gota program it. i just did that swap.
Old Feb 28, 2010 | 03:04 PM
Supermarkers
can that be done manually, or done at my ford dealer?
Old Feb 28, 2010 | 03:11 PM
highteckredneck
i took mine into the ford dealership and they did it for 60 bucks.
Old Feb 28, 2010 | 04:35 PM
Supermarkers
ty for your help guys!
Bluethunder3320
Apr 6, 2014 08:12 AM
Handegard
Feb 22, 2014 11:27 AM
FLJ
Electrical Systems/Wiring
May 30, 2009 04:01 AM
cobrasjj
Jan 28, 2008 07:44 AM
mikey67156
Feb 2, 2002 11:45 AM
